05-22-2020, 03:09 PM   #16
just to follow up...
Just to follow-up. When I held down the lens release button as suggested by "Not a Number", I was able to rotate the lens about another 10 degrees. I no longer heard a scraping noise that must have of been associated with hanging up the lens. So the lens completed seated.
Also I realized (my bad) that there is supposed to be a gap at the very outside of the lens at the OD as stated by "Lowell Goudge". Unlike the other lenses I have the aperture ring of this lens is against the camera body. So there needs to be a gap between the aperture ring and camera so the ring can rotate without rubbing on the camera body. The aperture ring is slightly offset from the lens mount.
Thanks to all of you for your replies and help.
adapter, camera, check, drive, focus, fujinon 55mm, gap, issue & infinity, lens, lens mounting issue, m42 lens, m42 mounting issue, mount, notch, pentax help, photography, screw, seat, shaft, smooth, tab, troubleshooting
Fujinon 55mm f2.2 (M42) pepperberry farm Lens Sample Photo Archive 30 11-21-2019 10:25 AM
Trouble Mounting an M42 lens via an M42-K Adapter onto K-mount Bodies fwcetus Pentax SLR Lens Discussion 9 09-19-2015 02:51 PM
For Sale - Sold: M42 Lenses. Pentax Taks 35mm, 135mm, 55mm, Fujinon 55mm Peter Zack Sold Items 5 03-04-2010 05:24 PM
All times are GMT -7. The time now is 10:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
