05-10-2020, 05:57 PM   #1
Pentax KX - can't change aperture or
Hi all. I recently bought a Pentax KX off eBay. Low shutter count and apparently good working camera. However, I can't seem to get the aperture dial to work. When I have the camera in manual mode, The aperture will go down for a couple stops and then all of a sudden go back up. It won't stick on anyone aperture value outside of the ones at the very extreme. I don't know what's going on. I also can't switch the +- stops. Always drifts to 3+ in manual mode. Thoughts?
05-10-2020, 07:04 PM   #2
Not a Number's Avatar
Maybe the white aperture solenoid was harvested and a defective green one put in its place.
Get your money back.
05-10-2020, 07:06 PM   #3
Otis Memorial Pentaxian
By aperture, is it safe to assume you mean the e-dial at top rear of the camera?
Do you have a copy of the manual? If not, you can download from the Ricoh Imaging Japan Web site.
Operation Manuals Download : Support & Service | RICOH IMAGING
The default behavior of the e-dial in M-mode is to change the shutter speed. To change aperture, press the +/-Av button while turning the e-dial. Automatic exposure compensation (+/-) is not available in M-mode. The meter-recommended exposure is displayed on the rear LCD in the +/- pane. Adjust shutter speed and aperture to center the indicator in the +/i pane.
Neither the set shutter speed nor the set aperture should change by itself once set in M-mode. The only exception is if the green button is pressed. In that case, the meter reading is applied to change the settings. How they are changed is explained in the manual and are configured in the capture menu.
The graph display in the +/- pane will change according to the light coming through the lens. You are safe to ignore this unless you are wanting to change the exposure.
One more thing, in regards to metering...unless you are confident as to why amd how you might use spot metering, it is best to use either multi-segment or center-average as the meter setting.
If behavior is other than what I described, there may be a problem with the camera, meaning that a request to the seller to return might be a good idea.
05-10-2020, 07:08 PM   #4
??????? I guess the post might be interpreted as aperture control failure during exposure, but I took it to mean difficulty setting aperture and having the value stick.
05-10-2020, 08:21 PM   #5
builttospill's Avatar
The aperture ring on a KX is always on the lens, not the camera.
I'm guessing aboslett purchased a K-x, very different from the 1975 KX film camera. Are you using a zoom lens with a variable aperture? If you set the aperture to an extreme, i.e., wide open, and then zoom in with the lens, the aperture will adjust automatically, becoming smaller (higher f/stop).
What lens are you using with the K-x? Do the connecting levers and contacts look straight and clean? When you say the +- being at +3, are you talking about exposure compensation? If so, here's a thread about this on the K-x: ev adjust in manual mode on k-x - PentaxForums.com
05-11-2020, 12:46 AM   #6
QuoteOriginally posted by aboslett Quote
With "aperture dial" you mean the dial left to the AF/AE-L button, i.e. the thumbwheel?
If so, this is a common issue with the K-x, the seller should have noticed because this problem starts slowly and then gets worse, it is a contact problem and pretty easy to repair and it is so that even in M-Mode you can't dial prober values:
Tutorial E-Dial (Thumbwheel) Repair Pentax K-r, K-x and K-m (K2000) - PentaxForums.com
It can happen with low shuttercount because the thumbwheel isn't WR and with dirty/sweaty fingers dirt can enter pretty easy.
But also just moisture through humidity in the air, particular near the sea or lakes can cause it!
So let us know.
05-11-2020, 05:02 AM   #7
Fixed the thumbwheel of my K-x by spraying with electronic cleaning spray. Batteries out and just a small spray into the wheel and couple turns, then let dry for a moment. Cheap, fast and easy, has been working for about two years now.
If that won´t help then some of the above methods
edit: ignore this advise!!
05-11-2020, 06:43 AM   #8
We had this discussion before, so just a short answer:
I have plenty experience with all sorts of electronic cleaning sprays. So often used in Audio just for volume potentiometers, it NEVER EVER worked on long term!
I have studied the effects there plenty of times, even under the microscope.
It can work for a time but often does more damage than good over a longer period.
I had several K5's (which are WR) were people used even high quality electronic cleaning spray, even so called tuner-spray, the most sensitive... and it was the final exodus!
My strong recommendation: Stay away as far as possible from such solutions!
05-11-2020, 09:00 AM - 1 Like   #9
QuoteOriginally posted by photogem Quote
Hmm, i guess i have to rethink my habits then. I´ve been using those sprays for amplifiers and all things with contacts with good results, but yeah, it might not be good after all in the long run. Cheap and easy, of course... Just never thought about it too much
Thanks for the insight!
aperture, camera, change aperture, kx, kx can't change, mode, pentax, pentax help, pentax kx, photography, troubleshooting
To change mount, or not to change mount? IgorZ Troubleshooting and Beginner Help 6 10-09-2018 01:34 PM
Aperture control problems with variable aperture lenses (with aperture rings) gtxSeries Troubleshooting and Beginner Help 3 09-13-2017 01:11 PM
how to change aperture on Kx? 4ngi3 Troubleshooting and Beginner Help 24 04-30-2014 11:10 PM
Hope and Change , "Hey mister can you spare some change?" seacapt General Talk 19 04-13-2010 05:56 AM
To change lenses or not to change lenses. That is the question. atyab Photographic Technique 28 11-24-2008 09:27 AM
All times are GMT -7. The time now is 09:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
