05-21-2020, 06:06 AM   #1
Asahi pentax spotmatic sp shutter release button stuck
Hi guys
I just got an asahi pentax spotmatic sp and as i look at it i see that the shutter release button isn't raised and you cant click it
Any idea as to why and how to fix it?
05-21-2020, 06:31 AM   #2
Not a Number's Avatar
Looks like the self timer lever is stuck in the cocked position. The lubrication gumming up in old cameras is a common problem. There are some DYI videos on youtube addressing stuck shutter as well as self timer problems. You can also find various service manuals for Spotmatics on pentax-manuals.com and other sources. Google search is your friend.
Pentax Manuals
If you don't have the tools and expertise or skills for a DYA repair consider having it serviced professionally. Any old school camera technician should be able to work on a Spotmatic.
05-21-2020, 09:04 AM   #3
Otis Memorial Pentaxian
Welcome to the Pentax Forums!
Yes, there is a problem with the shutter mechanism as it operates with the self-timer and yes, self-timer failures are very common with older cameras. While it is possible to attempt the fix yourself, freeing up this problem is something that would normally be addressed as part of a normal CLA (Clean Lube Adjust) along with stuff like shutter and meter calibration and replacing the light seals and mirror bumper materials. Your Spotmatic II is a fine tool and worth having the CLA done.
05-21-2020, 09:50 AM   #4
35mmfilmfan's Avatar
No criticism intended, but the whole thing looks in need of a little care and attention. However, whether it is financially worthwhile getting a CLA depends on how much it cost you. Good luck anyway.
05-21-2020, 11:16 AM   #5
I suspect the self timer has nothing to do with the shutter issue. Frequently when the shutter jams people will try using the self timer to see if that gets the shutter to fire. But yes, looks like it will need a bit of disassembly.
asahi pentax spotmatic, button, camera, pentax, pentax help, pentax spotmatic sp, photography, release, shutter release button, sp, sp shutter release, spotmatic, spotmatic sp shutter, troubleshooting
Pentax ME - Shutter release button stuck Sandra Troubleshooting and Beginner Help 4 01-17-2017 08:38 AM
Shutter not opening, shutter button stuck and unresponsive ( Pentax ME) pentytaxy Troubleshooting and Beginner Help 4 04-16-2016 12:54 AM
K-x shutter release button stuck? Priit Visitors' Center 3 10-25-2011 01:40 AM
P645n shutter release button/contacts stuck pe645user Pentax Medium Format 2 09-12-2010 07:45 AM
problem with spotmatic sp shutter release button cvsuave Pentax Film SLR Discussion 3 04-21-2009 04:41 AM
All times are GMT -7. The time now is 08:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
