Originally posted by Sandy Hancock Spot metering might be part of the problem too. It might have metered off the white of the panda (right in the middle of the frame), leaving the rest of the image relatively underexposed.
Definitely. Best not to use the spot metering until you learn how and when to employ it. Use the matrix/segmented metering (the usual by default). Underexposure also will to a greater degree reveal the noise/grain "pixels" you are seeing, which are the result of using such a high ISO.
The reason Sandy recommends using a tripod is he also recommends using f/11, which is setting your aperture to a narrower value (larger number means smaller aperture), which lets in less light so your shutter speed will have to be quite slow to compensate, too slow for hand-held shooting without blur from the body's slight motion. The reason for this compromise of f/11 and less incoming light is a smaller aperture also increases depth-of-field (DOF) meaning more of what is in the background and foreground of your shot will be sharp in addition to your main subject.
Putting your camera's AF sensors to center-only spot AF will give you the ability to train focus more accurately where you want it to be. Use the half-press of the shutter button to achieve and hold your focus, then press the rest of the way to fire the shot.
Don't have your camera's mode dial on the green "auto" mode, as this will disallow making most adjustments. Use the P (Program) mode for your fully automatic exposure setting, or for aperture control use Av as Sandy suggests.
The K-x probably has Custom Image settings. Default will be in the "Bright" category. Access its menu and tab down to the bottom Sharpness department, then using your rear thumb dial I believe, add "F"- for "Fine Sharpening".
The moderate adjustments luftfuss has made to your image gives you a good idea of what your camera actually delivered, even though not having an ideal setup.
Getting back to the narrower aperture and greater DOF, from this you can see that controlling DOF by controlling aperture is often an important factor that your phone cannot do. By using this same control of DOF, by your own choice you can use a larger aperture to deliberately reduce DOF so your subject will be sharper than surrounding objects, and will thus better stand out in your composition. Your choice and your control.
