Originally posted by patrickmb Hello everyone,
I recently bought and started using a K-70 and love using the astrophotography function. However, after long exposures I often will have to wait longer than the exposure itself for the camera to be useable again. The orange light is flashing during this down time which I believe to mean the data is writing to the SD card. Is this normal? Is there anyway to reduce this time?
Thanks for your help!
The long "write time" is actually the camera doing it's high ISO or long shutter time noise reduction. Both features can be disabled, but at the expense of noisier images. It is possible to take separate "dark frames" then combine everything in software later ... the same set of dark frames can be used over and over again, so once having taken them once, you'll not need any more that session provided the other parameters such as focal length and exposure time remain the same.
For reference, my brief tests indicate an exposure of 30sec with 400 ISO to be as long as the camera will go before invoking noise reduction. With a wide-aperture lens this is often more than enough in an area where sky-glow is a problem
Good luck
