Originally posted by riffraffselbow One other issue that I may have been confusing with this at least some of the time was that my shutter speed knob doesn't have the clicky detents and instead spins 'freely" and it seems the shutter will open but not close if the speed selector is 'between' speeds (i.e. not making contact w
This means the shutter speed dial indents have been stripped, so a full repair of both the dial and the indent pawl and probably the circuit if it has been abraded, would be required. There is one condition that is normal with the setting of the shutter speed, when it is placed in the black space after 1000 and X or B. The shutter can be opened but will not close until the dial has been set to one of the marked speeds., and this is intentional.
I suspect your camera requires a whole replacement shutter assembly and counterweight. There are no new assemblies available; parts are scavenged from like-cameras, which introduces reliability and redundancy problems, so all up, you may be better off buying a replacement 67 camera with no faults.
