Originally posted by dpkdpk10 When the battery is connected (no matter, if the camera is turned on or not) all the segments of the LCD are constantly activated. It doesn't react on any button press.
Has anyone encountered such a problem before or knows a solution ?
I think Mark Jerling's advice is a good one. But you could also have a look at the contacts in the battery compartment. If you take out the battery then all segments are on as well? It means it got stuck in a kind of reset mode of the display. Removing the battery and putting a fresh one in or putting fresh AA's in might solve the problem. As it is a classic camera
cleaning the contacts is not a bad idea as it has seen the sunlight outdoors in all that time, or maybe have been in a humid air. I own two SFX's one of the the n version. If you take out the battery the display should be blank.
