Originally posted by aslyfox
That review does mention the lens missing focus sometimes despite the camera reporting it has found it. I can confirm this happens on my K5. I don't know how to describe it but if you hit the AF a few times, the lens sometimes 'creeps'. When it stops creeping it's got focus. it doesn't happen all the time, so far it's the one fault I've found.
---------- Post added 25-06-20 at 04:36 AM ----------
Originally posted by ajaya
Thanks for the responses. Yes i did tried with tripod once but not found much difference. also can you please let me know how to get the AF fine tuned ?
I don't know the Kr, I think the Kr just has a generic overall AF fine adjustment, which means it'll adjust the AF for all lenses so that will be something to be aware of. It may mean that every time you put the Sigma on you'll need to adjust the AF fine adjustment in the menu and remember to reset it when you take it off.
There are volumes on AF fine adjustment and to do it properly you'll need a tripod and AF scale. You can though do a quick and dirty method which will tell you if your AF is out for that lens. So pick somewhere in the middle of the zoom, mount it on a tripod is best, point the camera at a wall, say 10 or 15 feet as a start, at a 45 degree angle and then shoot the same spot at 0, 5, 10 -5, -10 in the AF fine adjustment (your own Kr scale might be different to my K5). Examine them and see which one gives you the best focus for your lens. Then conduct further tests around the one yielding the best results but at lower increments. You can then repeat those test at different zoom lengths and distances to the subject. To do it properly you should get the AF focus scale but that method will yield decentish results and will very quickly tell you if the AF is out. It is quite easy to get wrong, so take your time.
