07-08-2020, 05:36 AM   #1
Supporting a longer lens
I have two Manfrotto heads (https://www.manfrotto.com/uk-en/x-pro-3-way-tripod-head-with-retractable-levers-mhxpro-3w/) that have a built in quick release construction to fit their 200pl plates. I have multiple 200pl plates attached to my cameras, so I'm rather trapped, but the Manfrotto system does work well enough for the gear I have.
However, to support a DFA 70-210 f4, I could try and attach the Tamron collar, but that uses an Arca fitting, or I could use Manfrotto's 293 telephoto support (https://www.manfrotto.com/uk-en/telephoto-lens-support-293/).
Anyone, any suggestions on how I might support this lens on one my two Manfrotto heads?
Many thanks.
07-08-2020, 06:02 AM   #2
amateur dirt farmer
pepperberry farm's Avatar
is the support necessary?
07-08-2020, 06:40 AM   #3
UncleVanya's Avatar
QuoteOriginally posted by BarryE Quote
Many thanks.
Does the arca fitting on the collar have a tripod socket to attach the Manfrotto plate? If not the knock off collars on eBay do offer that feature from what I can see.
Lens Collar Foot for Tamron 70-210mm f4 Di VC USD Lens A034 A034TM Built-in Arca | eBay
07-08-2020, 07:13 AM - 1 Like   #4
QuoteOriginally posted by pepperberry farm Quote
Possibly not, except I'm trying to reduce the effects of wind ...
07-08-2020, 07:16 AM   #5
amateur dirt farmer
gotcha - I just your other post about this issue and your thumb.....
07-08-2020, 07:28 AM   #6
Seeker of Knowledge
aslyfox's Avatar
this article might be helpful
Shooting Long Exposures Hand-Held
Member photographic article
By PF Staff in Articles and Tips on Feb 18, 2012
Do you want to learn how to make the most of hand-held shots? Our first member-submitted photographic article, written by Heie, discusses four different techniques for holiding your camera more steadily, and, in turn, getting sharper photos! . . /
Read more at: Shooting Long Exposures Hand-Held - Articles and Tips | PentaxForums.com
it was for me
07-08-2020, 10:11 AM   #7
QuoteOriginally posted by aslyfox Quote
it was for me
Thanks Allen, I'll take a look. Meanwhile I spotted https://www.manfrotto.com/uk-en/telephoto-lens-support-293/ which, if it works will give support and allow me to use my 200pl plates. I'll feed how it works ...
07-08-2020, 10:12 AM   #8
Lowell Goudge's Avatar
if you are trying to reduce wind, it is likely more important to put weight on your tripod than modify or change the mount point of the lens to the tripod, usually people have bags with straps already set up and you fill them with sand or rocks aquired locally to balast the tripod and ad stability
07-08-2020, 10:21 AM   #9
Thanks, I've ordered some bungy straps to attach to my camera bag. The Manfrotto support gives me another option as the bag test I initially made only partially helped. Having options, seems the best idea.
07-08-2020, 10:30 AM   #10
Manfrotto 293 lens support?
07-08-2020, 11:02 AM   #11
QuoteOriginally posted by JohnX Quote
Thanks John Just found that device (our postings crossed)
07-08-2020, 11:23 AM   #12
thats an option but a 70-200 F4 is supposed to be light, not the same as my sigma 70-200/2.8 that weighs 1.7 kilos
07-08-2020, 11:59 AM   #13
gofour3's Avatar
I had the Manfrotto 293 long lens support. The only issue I had was it only supports 2.5kg, which was not enough for the camera/lens combo I was hoping to use it for. Also the strap around the front of the lens may interfere with focusing.
Phil.
07-08-2020, 12:16 PM   #14
StiffLegged's Avatar
QuoteOriginally posted by gofour3 Quote
I saw that too in the specs – for the money I'd be looking elsewhere!
07-08-2020, 03:29 PM - 1 Like   #15
F/8 & Somewhere
TedH42's Avatar
The Tamron foot that fits the DFA 70-210 DOES have a tripod socket. I attach my Manfrotto plate to the foot - works great.
camera, heads, lens, manfrotto, pentax help, photography, plates, support, troubleshooting
Supporting a D FA 150-450mm lens: Use existing Arca-Swiss ball head or get a gimbal? bwDraco Pentax Camera and Field Accessories 28 12-03-2019 12:27 PM
Nature Awesome looking flower with wonderful supporting colors. Tonytee Post Your Photos! 2 04-12-2019 06:02 AM
Supporting accurate in-camera focus validation Class A Product Suggestions and Feedback 4 01-26-2019 06:45 AM
Question A Supporting Dealers List? AlwaysAl Site Suggestions and Help 14 01-17-2019 06:38 AM
Question I no longer use PayPal......I no longer accept PayPal.....Can I still sell on PF ?? Dlanor Sekao Site Suggestions and Help 8 04-07-2016 07:38 PM
All times are GMT -7. The time now is 12:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
