First of all, thank you guys for your quick responses
Quote: Have you tried pixel mapping?
Yes, it did not help
Quote: Check White Balance settings?
Nothing special, it is set to Auto White Balance. If I set to something different, there is a slight change, but still purple...
Quote: What lens do you have on?
Tried with different lens (Sigma 10-20, Tamron 17-50, Pentax 50/1.7 - Manual), the results are the same.
Quote: Sounds likely (for whatever reason), especially since you see it in LV. Use PhotoShop (or equivalent) to display the 3-color histogram
I have attached the color histogram for the posted image, never seen something like this...
A funny thing that I noticed, if I turn up the ISO, the colors starts to appear. I have a bad feeling, that this is some sensor issue....
