07-15-2020, 12:38 AM   #16
I guess you use the DA-L 18-55 which has a 52mm thread for filters.
Do a factory reset (menu - wrench symbol 3)
A deeper reset goes through the debug menu applying "USR DAT CLEAR"
k-x factory reset - PentaxForums.com
07-15-2020, 08:13 AM   #17
QuoteOriginally posted by CarlJF Quote
When you focus manually, does the green hexagon light up in the viewfinder ? If so, it means the AF sensor works fine since the focus confirmation is the same system. Said otherwise, the green hexagon lights up when the AF system detects the focus is ok. If there's a problem with the AF sensor, the green hexagon will not light up.
I see the hexagon but it's flashing, not staying lit up. Is that something I'll have to take to a shop to fix?
---------- Post added 07-15-20 at 08:16 AM ----------
QuoteOriginally posted by photogem Quote
I'll give that a shot. I did a basic factory reset recently but not a deeper reset.
07-15-2020, 08:50 AM   #18
QuoteOriginally posted by liam_wilk Quote
It should lock, stay lit and then the confirmation beep indicates focus locked in.
Which mode are you using?
AUTO, Scene, Av, Tv?
Normally a basic reset would be enough if anything was programmed in a way not conform with your settings/modes
07-15-2020, 10:10 AM   #19
I've used all of those modes and it does the same thing. Manual mode, Av, Tv, portrait, night scene etc... nothing changes it. I did do another reset and no luck.
07-15-2020, 10:23 AM   #20
Maybe you all can try taking a look at this video? Had to put it in a .zip folder to upload so you may have to download to view it... let me know if this helps?
07-15-2020, 11:56 PM   #21
Hardly anybody will open a zip-folder because they can be zip-bombs!
It's possible to upload videos here or, if too large, there are other possibilities.
07-26-2020, 09:22 AM   #22
I may try to take it to a shop somewhat nearby - camera shops are hard to come by in the TVA.
Anyone with recommendations please let me know as well! Thanks again to everyone!
af, auto, auto focus, button, camera, factory, focus, help, hexagon, lens, light, menu, mirror, pentax help, photography, post, press, reset, sensor, shot, subject, system, times, troubleshooting
DA* 60-250 lens won't auto focus MikeD Pentax SLR Lens Discussion 10 02-15-2018 10:30 AM
Architecture I won, I won, I won Culture Post Your Photos! 12 11-13-2015 11:34 PM
"Click" in between "C" and "MF" mode on focus selector? K-50 maxwolfie Pentax K-30 & K-50 3 01-29-2015 04:19 AM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
Kx video jumpy after codec for CS4 P12 Video and Pentax HDSLRs 3 07-04-2012 08:25 PM
All times are GMT -7. The time now is 02:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
