Dear all,
I've got so many nice thoughts and I really appreciate it! I'd repeat myself if I'd answer to each one of you so I rather pour out!
So the current setup is the following (though I'm of course ready to modify it if it’ll lead to a solution):
-Manfrotto tripod with a ball head
-two negative carrier (35mm and 6x9)
-Vorsatz M42 bellows
-SMC Takumar 55mm 1.8
-iPhone and a plexiglass on the top (though I'm thinking about getting a slim light panel)
-and a currently not purchased DSLR (as I have a M42 to F Mount adaptor in my drawer anyway I'm thinking about getting a Nikon D3200/3300)
At the moment I've tried the Takumar on the bellows (fully closed) and attached it to the Spotmatic just to check the outcome. It works and covers the entire frame when I look through the viewfinder. The Takumar is a nice piece of glass I love it but it failed in this setup and I've tried it reversed though I knew that it might be worse and yes; in both cases the edges are blurred. Even and the overall quality was somewhat worse, knowing what this lens is capable of otherwise.
I'm thinking about getting an enlarger lens but I also have to think about the 6x7 negs as well so I might get an 80mm enlarging lens or a dedicated macro. I want even sharpness of course.
I don’t know if the 80mm enlarging lens is a good idea or which macro would be good for both formats/distances but that’s the reason I composed these lines to get some help to setup the fun.
Thanks in advance!
