Originally posted by Philtax
Hi, I've just joined (after occasionally lurking for many years!). Had some birthday cash to spare so recently upgraded from my K20D to a second-hand K3 - which I still have the option to return and seriously thinking about as I find it difficult to get used to compared to the K20D. One issue someone might advise on please: I have been doing some test shots of the same scene at different apertures and find the wheel sticks after a few changes - is there a valid reason for this or is it a technical fault with the camera? It frees up again if I lightly press the shutter release button. Never happened on the K20D.
I think I know what is happening here.
After you take a picture the "instant review" image is displayed on the rear LCD screen for a short while. While the image is being displayed, any movement of the rear dial acts as the zoom function for the review image. So if you try and change the aperture while the review is displayed you will find it does not work. As you discovered, a half press of the shutter cancels the display and the rear wheel now controls aperture again. this is perfectly normal.
The length of time the review shows on the rear screen can be customised in the camera menu or even turned off completely. I have mine set to 3 seconds. That is enough time for me to look at the histogram which is all I am interested in at that stage to check exposure. It should also be possible for you to disable the zoom function during review (it is on my K1).
All the above only apples to the "instant review" which appears when you capture a single picture or in the case of a burst of pictures only displays the last one. To view and zoom your captured pictures you use the Playback button.
Hope this helps.
