Originally posted by Joats
Not sure its a poor contact issue. Why would the camera work with Eneloops (that are less than 1.5v) and no other AA battery? This was an issue that came up ten years ago with the 100D cameras, and continued with the Kx. The issue, if I remember correctly, had to do with the battery chemistry. Pentax then released an update which it claimed would fix the issue for some, but not all cameras. My Kx has the latest firmware when I bought it, and still had a problem. First it worked with standard Duracells, then after a while it would show a Battery Depleted sign, even with new batteries. Then I was recommended Energizer Ultimate Lithium. These worked, for a while, then I got the same Battery Depleted sign. Someone said Eneloops were the only way. I have had two sets of those and they have always worked, although even here, they don't work for very long, you have to keep them charged fully. With four Energizer Ultimate Lithiums, the camera now won't even come on. I have cleaned the contacts several times to no avail.
Joats
Both problems are common:
1. contact (which you checked)
2. Quality off AA batteries:
Here you need to make sure that:
- latest firmware 1.03
- change in menu from AUTO to LI-ION!
Eneloop Pro are a good idea, because they have that extra capacity. They do discharge with 3% compared to the 1% of the standard Eneloops.
This means after 14 month of not being used the Pro-version has reached the same capacity of the standard version, not bad at all and thus worth to be considered. The extra capacity is worth it I find. But all good rechargeables need for sure a really good charger, the cheap Panasonics are not really the best.
2nd difference is how long they last: Standard 1000 chargings, the Pro's 500 chargings.
Means that if you charge once a month, the Pros last 41 years, the standard version 82 years.
Says it all!
Anyway, I stop this theme because actually it would belong into a different thread which you could start if necessary!
Hope your K70 problems will be solved, it is a nice body.
If it ever would experience the "dark-image-syndrom", then study:
Tutorial/Repair Pentax K-70 with aperture-problem: Exchange solenoid - PentaxForums.com
It is less likely with the K70 as Ricoh did work at the solenoid which is
the only culprit if that very problem happens, if you want to know more about it:
A LITTLE BIT OF HISTORY: Development of the solenoid in Pentax cameras - PentaxForums.com
