2 Days Ago   #1
Problem with K-50
Problem with my K-50 when I turn I get a grinding noise and it will not connect to my computer to download pictures, any help would be appreciated.
2 Days Ago   #2
CarlJF's Avatar
The noise might be the sensor cleaning system doing its job. It's easy to check by disabling the sensor cleaning in the menus. If the noise goes away, it means it's that and perfectly normal. It's then yours to decide if you want to keep it on or off. Although the noise isn't a big problem compared to a dirty sensor...
To download pictures it's usually better to use a card reader. Is the camera turned on when you try transfering the pictures ?
2 Days Ago   #3
Not a Number's Avatar
File transfer connection problems are usually cause by cable or port problems try a different cable and/or port. Also try changing the the Transfer Mode setting in the camera's setup menu.
I don't recall if the K-30 uses a standard USB connector or one with a non-standard connector found on many cameras. If it is a standard USB connector make sure the cable is a data cable and not a charging only cable.
2 Days Ago   #4
QuoteOriginally posted by CarlJF Quote
Absolutely. They are inexpensive and widely-sold, in addition to being easy to use. They connect via USB, and then you can already have a new folder made and named to select for your download. And welcome to the forum!
1 Day Ago   #5
The K-30 uses a standard midi-USB output named "video" which should work fine if healthy.
Changing USB transfer (Menu wrench symbol - 2) can work:
PTP = Picture Transfer Protocol is supported since XP days. MSC = Mass Storage Class is the factorysetting and probably what is trying to load a driver.
If it is an old computer: You need DCU installed for MSC, if your Windows install doesn't automatically find a driver for it. But then this would mean it hasn't worked before.
Switch to PTP or .... if the camera is already in PTP then switch it to MSC. If that doesn't work, switch back again!
Maybe that will solve it.
Use a port directly on your computer and not something attached to some hub or similar like an USB connection on your monitor!
Try also USB 2.0 and USB 3.0 ports if available!
External card-readers are not only better/faster/more convinient but protect your camera.
Every USB port can go wrong if used often. Contacts wear off, can bend or even broken contacts inside the camera.
As it was mentioned, an external cardreader is cheap. So before you buy another cable you are better of with a card-reader.
The noice when turning the K30 is most likely the antishake of the sensor, can be quite loud with your K-30.
1 Day Ago   #6
CarlJF's Avatar
BTW, if you have a laptop there’s a good chance it already has a slot to read SD cards. So you might not even need to buy a card reader!
1 Day Ago   #7
I did solve the problem of downloading my pictures, I concluded that the cord was not inserted properly. As far as the grinding noise when I turn on my camera I have no idea what is causing that, I gave my camera a good cleaning hoping that would help but sound is still there when I first turn on the camera. Any idea what could be causing this?
---------- Post added 08-03-20 at 12:00 PM ----------
Thank you for reply, did solve the downloading problem, cord was not inserted all the way. I am more concerned about the grinding sound when I first turn on my camera, do you have any thoughts about what could be causing this to happen?
---------- Post added 08-03-20 at 12:01 PM ----------
QuoteOriginally posted by mikesbike Quote
Thank you.
1 Day Ago   #8
CarlJF's Avatar
As mentioned above, the noise can be the sensor automatic cleaning feature which is quite noisy on the k-50. By default it will clean the sensor every time the camera is turned on. To clean the sensor, the camera rapidly shakes it, giving a unusual noise which can be described as grinding noise.
You can go in the camera menu and deactivate this feature and check if the noise is still there. If you don’t hear it when the feature is off it will confirm that what you heard was the sensor cleaning and perfectly normal.
13 Hours Ago   #9
Seeker of Knowledge
aslyfox's Avatar
in case the OP doesn't have the operating manual, here is a link:
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k-50.pdf
pg 266 might be helpful
cable, camera, connector, k-50, noise, pentax help, photography, pictures, port, sensor, sound, transfer, troubleshooting, usb
Pentax Optio E 50 camera connection problem Problem Nat Welcomes and Introductions 2 12-18-2019 08:04 PM
For Sale - Sold: Pentax K-m + 50-135 + F 100 macro + sigma 17-70 + 50-150 + tamron 17-50 + metz 50 AF blem49 Sold Items 11 07-26-2013 03:25 PM
For Sale - Sold: K-5, 16-50,50-135,65-250, Sigma 17-50, 50 1.4, 50 1.8, Tamron 90 2.8, Flashes virarfast Sold Items 8 04-04-2013 02:30 PM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
For Sale - Sold: SMC Pentax-A 50's: 50/2.8 Macro, 50/1.4, 50/1.7, 50/2 arpaagent Sold Items 14 01-16-2009 08:06 PM
All times are GMT -7. The time now is 04:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
