08-04-2020, 01:47 AM   #1
Pentax KM/K200 AutoFocus stopped working
HI all,
I have a Pentax KM/K200 with a Tamron lens. I have had the camera for 5 years and never had an issue till now.
I was happily taking photos of a swarm of beautiful kites and the AutoFocus stopped working. I assumed that this was down to the battery levels getting low ( as this is what happens). However, after charging the batteries, by AF still does not work.
I have pressed the AF button several times, although nothing comes up on the display or anything, the display just turns off and on. Unfortunately I do not have another lens, to test if it's that.
I am happy taking manual focused so its not a huge bother, I just like the AF feature when I have gone for a walk and don't want to wear my contact lenses. Its then hard to manual focus as it looks in focus to my bad eyes, but when I look on my PC its as blurry as anything. The AF helps my poor eyesight!
08-04-2020, 02:03 AM   #2
Not a Number's Avatar
Did you by chance switch the camera from AF to MF?
08-04-2020, 02:39 AM   #3
If it isn't the switched off AF-M Button on the side which was accidently switched off, then it might be the screwdrive-motor.
This motor is pretty weak in the K-m/K2000 (the K200D is a completly different Pentax!).
Same motor in the K-x as well, which had Live-View as well. If one used an AF-lens on the Kx such as even the old Tamron 28-200 and Live-View together, the motor could hardly move the screwdrivemechanism of larger/longer lenses.
Another possibility is that the mechanism in the lens itself is damaged. But this you only can find out if you have another AF-lens.
If so, time to get a more modern camera. The K-S1 is also very small and can be found pretty cheap. Hell of a camera for the money.
08-04-2020, 06:40 AM   #4
ChristianRock's Avatar
QuoteOriginally posted by photogem Quote
I agree with this... I upgraded my K-r (same body format basically as the K-m) to the K-S1 because the AF was pretty weak and the viewfinder was a bit too small... and never looked back. The K-S1 feels a tiny bit heavier despite being an even smaller camera than the K-m/K-x/K-r, but that's the price for that beautiful bright big pentaprism (same as the K-3).
Though I have to say I also picked up a K200D recently, and I think it's a superior camera to the K-m (haven't had a K-m so I can't tell for sure) - it feels great in the hands, has weather sealing and the top display, and has that beautiful CCD sensor that I like to use for a lot of things.
af, autofocus, camera, display, focus, lens, pentax, pentax help, pentax km/k200 autofocus, photography, tamron, troubleshooting
Pentax IstDs: left side buttons stopped working heki Troubleshooting and Beginner Help 6 10-08-2019 11:18 AM
Autofocus stopped working on new k3II knutta Pentax K-3 10 07-09-2016 03:56 AM
Pentax 645NII Autofocus suddenly stopped working Wolfeye Pentax Medium Format 2 12-20-2015 05:13 PM
Flash stopped working K200 Beth17 Troubleshooting and Beginner Help 1 05-09-2014 09:53 AM
Km or K200? skoobie Pentax DSLR Discussion 12 04-30-2009 09:48 PM
All times are GMT -7. The time now is 01:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
