08-06-2020, 02:49 AM   #1
ajaya's Avatar
Tamron 28-75 after lens clean is not getting detected!
Hi,
I got my tamron 28-75mm cleaned for fungus but after cleaning its not detecting in my KR, i tried below its not working. can anyone suggest me what should i try to get it work ?
1) cleaning camera mount and lens rear mount
2) tried to change the A ring to different value and use the lens in MF mode
3) try to switch to pentax lens and try back this lens.
08-06-2020, 02:57 AM   #2
dbs
Hi.
Check to see in the menus if the " using aperture ring " is permitted.
Dave
08-06-2020, 04:24 AM   #3
ajaya's Avatar
QuoteOriginally posted by dbs Quote
Hi.
Dave
Tried, still same issue.
08-06-2020, 07:31 AM   #4
enoeske's Avatar
Rub a pencil eraser on the lens' electrical contacts
08-06-2020, 07:34 AM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by ajaya Quote
Have you talked to the person that did the cleaning? If it worked before and did not work after, that might be your first line of inquiry.
08-06-2020, 08:07 AM   #6
ajaya's Avatar
Yes,i need to visit the center over weekend and check with them.
---------- Post added 08-06-2020 at 09:09 AM ----------
QuoteOriginally posted by enoeske Quote
Hey thanks, let me try this unique solution, hope it works !
---------- Post added 08-06-2020 at 09:12 AM ----------
Just for information, the Tamron 28-75mm lens is AF lens.
08-06-2020, 05:22 PM   #7
dbs
Sounds like they have not put it back together correctly.
Could you add a photo of the mount , maybe someone can see a difference.
08-17-2020, 06:11 AM   #8
ajaya's Avatar
Hi All, Please find the attached image of the lens mount section. I just tried today again after using pentax lens for a week and now i could see the Autofocus is working on the lens but F number i am not able change and still flashing ! so please let me know what could be the issue.
Thanks
08-17-2020, 07:30 AM   #9
Lowell Goudge's Avatar
i dont see anywhere to check the lens / aperture is in the A position? this lens does have an aperture ring, it will show F-- if not in the A position
08-17-2020, 11:41 AM - 1 Like   #10
Thanks
Did you ever talk to the shop that did the repair?
The short answer is that the contact fifth from the left, next to the white patch, is not being detected as having electrical continuity with the mount. This should always be the case when the aperture ring is in the "A" position and should never be the case when the ring is in other than the "A" position.
08-18-2020, 03:31 AM   #11
ajaya's Avatar
Yes it is at A postion
---------- Post added 08-18-2020 at 04:44 AM ----------
Thanks Steve, Shop is closed after i collected my lens due to COVID situation. Do you think is there anyway where i can cleanup the contact which you mentioned ?
08-18-2020, 04:22 AM   #12
All the contacts can be cleaned with isopropyl alcohol. Use a quip or soft cloth. Also move the lens in and out of the A position a few times, maybe the internal contact is dirty. This could be the case if it hasn’t moved in a while
08-18-2020, 09:00 AM   #13
I doubt this is a matter of cleaning. Instead, I suspect the service attempt resulted in a broken solder joint or wiring connection under the mount on the lens.
08-18-2020, 09:01 AM   #14
The lens was recently CLA'd (see original post) and the supplied photos show a clean mount.
08-18-2020, 09:05 AM   #15
I just took a closer look at the supplied photo. Is the mount tang at left bent? If so, that might be the source of your problem if the lens is not seated flat onto the camera.
aperture, camera, contact, lens, mount, pentax help, photography, position, post, shop, steve, tamron, tamronlense notworking, troubleshooting
80-200 F/2.8 lens not detected by k3 oswego-otter Pentax SLR Lens Discussion 4 12-17-2014 11:46 PM
Sigma flash 530 sometimes not detected by camera melbflyer Troubleshooting and Beginner Help 5 12-26-2012 02:44 AM
For Sale - Sold: K10D, Tamron 28-75 F2.8, Tamron 75-300 F4-5.6, Super-Tak 50/1.4, AF-360 Flash maconmatt Sold Items 5 10-25-2010 06:18 AM
To clean or not to clean ? seacapt Pentax SLR Lens Discussion 9 12-15-2008 04:29 AM
Tamron 28-75 soft at 50-75 but not at 28 at f/2.8? kenyee Pentax SLR Lens Discussion 9 08-29-2008 07:56 AM
All times are GMT -7. The time now is 08:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
