08-07-2020, 11:28 AM   #1
K-70 Interval Shooting
Just got a new K-70 and ready to start astrophotography
M setting only one to allow INT option
INT options are: Interval, Number of Shots, Start interval
My question regards Interval (time from start of photo to start of next photo); if you enter 30 sec how does the camera know each interval is 25 sec exposure, 5 sec to next photo start OR 20 sec exposure, 10 sec to next photo start?
08-07-2020, 12:33 PM   #2
Hi and welcome!
The interval shooting menu is the same thing as though you're mashing the shutter button only on a timer.
It's totally blind to whatever your Manual exposure settings are.
So if you set your interval to 30 seconds, and your manual shutter speed is 25 seconds, there'll be 5 seconds of gap before the next one
However, if you set your interval to shorter than the shutter speed (say 20 seconds, and your shutter speed is 25 seconds), it would shoot for the 25 seconds, then the next interval would be missed since the exposure is still going, but it'll pick you back up at the next 2x20 = 40 second interval.
Now keep in mind if the 2nd thing happens, you only get half the number of frames you set your intervalometer for because it's missing every other one.
08-07-2020, 12:52 PM - 1 Like   #3
photoptimist's Avatar
Think of the interval function as a stupid assistant that will mash the camera's shutter button for you every 30 seconds (or whatever number you enter). If the camera is done with the previous shot when the assistant hits the button, the camera will take the next shot. If the camera is NOT done with the previous shot when the assistant hits the button, the camera will NOT take the next shot (but the dumb assistant will count the attempt against the "number of shots' setting).
Thus you'll want to ensure that the interval time you enter is larger that the shutter time plus processing time (usually a few seconds depending on your post-processing settings). Don't forget that if you have long shutter time noise reduction enabled, the camera will need double the shutter time between intervals.
(Note: for obscure historical reasons, a 30 second shutter speed is really 32 seconds long and "15 sec" is 16 seconds!)
Interval shooting can be a lot of fun but it takes a bit of testing to get it right.
08-07-2020, 01:04 PM   #4
Seeker of Knowledge
aslyfox's Avatar
Welcome to the forums
you will find friendly members and a lot of knowledge here
08-07-2020, 02:50 PM   #5
thanks everyone! I guess my question is: with INT how do you set the shutter exposure time?
08-07-2020, 03:18 PM - 1 Like   #6
Man With A Camera
Racer X 69's Avatar
QuoteOriginally posted by CraigWA Quote
Use the shutter speed dial. The Dumb Assistant {intervalometer} only controls the time between shutter clicks.
When shooting star trails photosets, I set my camera for the longest shutter speed it will do, 30 seconds, I set the apertures somewhere between f6 and f10 (experiment), ISO from 100 to 600 (again, experiment). I set the interval for 40 seconds, giving the camera time to store the image data without overrunning the buffer.
I also use manual lenses, almost exclusively. Prefocus, use a long and somewhat overexposed shot to double check the focus, then leave it alone. Gaffer's tape helps here, especially when using some older lenses that have well worn focusing helicoids.
Oh, and welcome to the forums, from another resident of the Pacific Northwet.
08-07-2020, 05:17 PM   #7
Aaron28's Avatar
the shortest amount of time between shots is 2 seconds with interval shooting........
when i do star trails i set the interval time = exposure time + 2seconds......i.e. 20 second exposure interval is equal to 22 seconds.......25 seconds interval set to 27 seconds....30 seconds set interval to 32 seconds.......
it's been a good lil while but used to do sunset time lapse using Av mode......would set the interval anywhere between 15 to 30 seconds......since i would only go about 15 minutes after sunset the exposure would never exceed the 15 to 30 seconds to worrying about an overlap in time......
08-07-2020, 06:02 PM - 1 Like   #8
If you're doing star trails, I'd really encourage you not to use the built-in intervalometer.
By default, you're only capturing 93% of the trails (30/32) and thus will have tiny slices of gaps in between your stars.
What I recommend instead is to get a $10 wired remote. Set your exposure settings however you please, then flip the Drive mode to Continuous (H/M/L, doesn't matter). When you're ready to go, use the button lock on the wired remote, and let it go until you think you're done.
It'll shoot those 30 second frames over and over with unrecognizably small gaps in your star trails when you merge them all together.
08-07-2020, 07:51 PM   #9
Otis Memorial Pentaxian
QuoteOriginally posted by disasterfilm Quote
Well, that is an interesting variation that I had never thought of.
camera, exposure, int, interval, k-70, k-70 interval, pentax help, photo, photography, sec, troubleshooting
Combining interval shooting and a neutral filter on waterfalls jgnfld Photographic Technique 10 04-28-2020 10:02 AM
KP & K-70 Interval Shooting kypfer Pentax DSLR Discussion 2 03-17-2020 12:35 AM
K-70 problem with interval shooting ranmar850 Pentax K-70 5 03-11-2017 12:59 AM
interval movie on K-50 lowest interval 10sec? dvrapant Pentax K-30 & K-50 2 05-24-2016 12:13 AM
Continuous Shooting, Exposure Bracketing, Interval Shooting etc in B Mode! kamayok3 Pentax DSLR Discussion 8 02-12-2014 01:45 PM
All times are GMT -7. The time now is 07:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
