Originally posted by Selvadero Okay, thanks to all for the replies, I think I will stick with DNG unless someone knows of a problem with my model. I am using the K-70. Are there any known issues with Pentax's built-in conversion to DNG in this model? I would rather not be bothered with using the Adobe conversion software.
- I always shoot DNG ... starting with K-5, then K-1 and KP. Never had problems.
- Raw data is the same for PEF and DNG generated by the camera.
- White balance is independent from sensor data used when conversion is done, i.e. applied for the previews and post processing.
- DNG of new cameras will work with different and older Raw Converters, whereas PEF may be not supported.
- The Pentax in-camera DNG format is native Pentax raw format like PEF. Don't compare it with Adobe Converter created DNG. I use Capture One with Pentax in-camera generated DNG. Doesn't show problems IMO.
- To say something about different DNG files: the DNG raw files generated by VueScan when scanning negatives oder slides are different. They contain RGB tiff based data, not non-rgb sensor data like camera raw files.
- If you are an Exiftool user you'll realize that extracting the different JPG preview sizes will partially work different for PEF and DNG. If you're interested in details, have a look
here. Although written in German it should be clear what I talk about in this post.
