08-31-2020, 09:04 AM   #1
K50 images dark unless LV is on
We were comparing images between a K50 and a K200. The K 50 images were absurdly dark, even though both were set to Auto
In the course of messing about I discovered that selecting LV Liveview the images come out correct.
I actually reset factory defaults on the K50 in case it was some obscure setting, but it hasn't helped
Any ideas please
08-31-2020, 10:32 AM   #2
See the threads discussing aperture solenoid failure here:
Pentax K-30 & K-50 - PentaxForums.com
09-14-2020, 02:59 AM - 1 Like   #3
QuoteOriginally posted by shimself Quote
Any ideas please
It is the solenoid and you check as described here:
Detection of aperture block/diaphragm-block failure/stuck solenoid K-30, K-50, K500 - PentaxForums.com
Liveview does work for a time, but if you check EXIF-Data, you might notice that they don't match:
This is because in LV-Mode the camera has to measure with f4,0 but when the solenoid is stuck, aperture is full closed.
But because the solenoid actuates twice it often opens the 2.nd time and then enough light for the photo taken.
But the camera metered with f22 or f32, depending which AF-lens was used!
camera, dark, image, images, k50, k50 images, liveview, lv, pentax help, photography, troubleshooting
Dark frames or dark expositure problems in KS2, K30, K50, etc. sergiogonzalez Pentax K-S1 & K-S2 163 02-01-2022 02:04 PM
Dark RAW images from K50 shanx Pentax K-30 & K-50 18 01-04-2016 09:31 AM
Do you test your lenses' IQ or accept them unless you see something obvious? BigMackCam Pentax SLR Lens Discussion 50 11-23-2015 11:06 AM
K50 Screwmount Metering Issues: Green Button Meters in LV but not in VF Relativity Pentax K-30 & K-50 5 01-31-2014 10:17 AM
Newbie unless you count read only :-) Pat Contor Welcomes and Introductions 3 02-04-2010 10:57 PM
All times are GMT -7. The time now is 11:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
