Originally posted by jrdimond The USSR lenses have no pin and unlock the adapter when
unscrewed, thus the problem.
That I understand. The adapter has a metal catch that engages with the camera's mount that is supposed to hold it in place until you release it. This is usually done with a fingernail. You should be able unmount your adapted lenses leaving the adapter attached to the camera.
In regards to the "pin" I mentioned above, that is a feature of SMC/S-M-C Takumar (Asahi Pentax made) lenses only.
Originally posted by jrdimond I hope I am not missing what your are saying.
Perhaps a bit. Your adapter may have been modified or damaged at some point. You should be able to insert it into the K-mount opening and rotate it in by hand and it should click into place with the release spring at the 10:00 o'clock position. If this happens without the lens, there is some sort of interaction with the lens that in interfering.
Originally posted by jrdimond OK, now we have been able to replicate the problem and I have a theory. I think there are to many threads on my USSR lenses, so they go too far into the adapter. The thin metal locking arm meets the threads for maybe 5mm before the lens is tight in the adapter. This shoves the locking arm slightly up, just enough that it barely touches the camera body mounting teeth (I don't know the correct term), not enough to lock the adapter in place. The extension tubes threads don't protrude into the adapter so far, don't touch the threads, therefore they work and the lens doesn't. The lens just goes too far in.
Do you concur?
The lens mount threads should not be in a position to interfere with the small metal spring tab that retains the adapter in the mount, even with a lens having longer thread depth. If the lens threads are shoving the lock spring out of place, your adapter has been damaged and/or might not be genuine Pentax.
As for losing infinity focus with the extension tubes...yes, that is what happens.
