Originally posted by Mooncatt If I may jump in for a second, can someone point me to some info on why AF fine tuning is needed from the technical standpoint? My last DSLR didn't have the ability, so this is pretty new to me. I'm just wondering how a camera can think a lens is in focus when the focus point is obviously blurry. I tried searching online and found a lot of how to fine tune, but not anything on why.
When you're shooting in Liveview mode, focus will be on point because the focussing points that determine if correct focus is achieved are directly on the very same sensor that will capture the photo. When you're not using Liveview and focussing while looking through the optical viewfinder, you see what the lens sees because the light that enters through the front of the lens will be redirected by a mirror in the camera body to the pentaprism viewfinder in the top section of the camera right into your eye. The mirror in the camera body that redirects the light from the middle of the camera body to the top so you can see what the lens sees, that very mirror is now directly in front of the sensor, so the sensor cannot see what you see, it is just flipping out of the way just in time for the shot after you pressed the shutter button. So the first mirror is not 100% reflective, but will let some light pass through to a secondary mirror behind it, which will send the light down to the bottom of the body where the AF sensor unit is placed. (Look up how a (D)SLR is built;
cross-section I found on Wikipedia. It's even a Pentax) In theory the way the light takes from the front of the lens to the sensor, and the way the light takes from the front of the lens down to the AF sensors should be the same (? or at least with some math work out to the same results), but because you now have a whole complex set of moving pieces in between the AF sensors and the lens, minimal differences in tolerances can have a huge effect on the focussing accuracy. Sometimes the same lens needs the same corrections on different bodies, while other lenses might need different corrections on the same bodies.
The good thing is that as long as those little differences in distance are not too long, you can use the fine tuning to correct for it.
This will be most obvious when you're working with small depth of field: with fast aperture lenses, long lenses and near close focussing distance. When focussing faraway things with wide angle lenses at small apertures, you're less likely to notice if the focussing is off a little because of the bigger dof.
