Originally posted by SidecarDan Hi All, thanks for your responses.
Live view does work but it's very dark and grainy, when I push the button down half way to focus it gets even darker.
I'm sitting at my computer and set the camera on M mode at iso 100 1/100 f8 and aimed at my computer screen, it's quite dark for a second or so while focusing and then goes completely black, when I push the button to take a picture nothing happens. It doesn't matter what I set the ISO, shutter speed or f-stop to when I push the button nothing happens, no picture. When I set it back to auto and try and take the same picture nothing happens now.
I will wait until daylight and try a couple of pictures outside and see what happens.
Regards, Dan
You should also try the following:
1. set the camera to operate in 'M' mode or 'Av' mode
2. set the camera body to the f-stop one down from wide-open {so if the lens goes from f/4 to f/22, set the camera to f/4.5} using a DA lens or a lens with the aperture set to 'A'
3. in a place where you can
see the aperture, take a photo
4. if the aperture flicks slightly tighter, the aperture control is OK; if the aperture closes to almost completely closed, the aperture control has a problem.
