2 Days Ago   #1
Pentax K1 Mark II - fires sometimes continuously in single frame mode
I didnt find something about that in the forum so excuse me if this was discussed already.
Sometimes, my K1 II fires continuously although set in single frame mode (no bracketing set). Is this an indication of dirt under the trigger button? I might consider a cleaning through service then.
Thx
2 Days Ago   #2
pjv
Otis Memorial Pentaxian
pjv's Avatar
Hi Andreas, I did a little digging and found the thread below. I hope this is of help, as it could be your issue. Good luck.
How bad of a thing is mirror flap? - PentaxForums.com
2 Days Ago   #3
QuoteOriginally posted by pjv Quote
Thanks, but I guess that's not it. Pictures are taken in my case. Camera behaves like on continuous shooting mode. Therefore my thinking of wonky contacts.
2 Days Ago   #4
pjv
pjv's Avatar
QuoteOriginally posted by yucafrita Quote
Yes, recording an image is very different. Now we know that, the answers you now get will be better.
2 Days Ago   #5
I had a similar problem on my K-70 ... turned out I was managing to accidently actuate the Drive Mode option on the 4-way controller with my thumb when using the camera hand-held with a long lens! There may be options to disable or change the functionality of this controller on your camera ... worth a try at least
2 Days Ago - 1 Like   #6
QuoteOriginally posted by kypfer Quote
Yeah, I checked that. It's not the case. I think I will have it cleaned. The rear dial sometimes doesn't respond, either.
Edit: I may experience the continuous shutter firing when I am only slightly pressing the button (back button AF). If I press firmly, I don't remember this happening. Could it be that the shutter in general is a bit fidgety?
2 Days Ago   #7
Paul the Sunman's Avatar
Just to be sure: you're not in any user mode, are you? I have a user mode for birds in flight that includes continuous shooting. If I ever accidentally leave the camera in that mode, I get multiple shots of course.
2 Days Ago   #8
sergysergy's Avatar
maybe you have activated continuous bracketing mode?
2 Days Ago   #9
QuoteOriginally posted by Paul the Sunman Quote
QuoteOriginally posted by sergysergy Quote
No, it was TAv. And it was bracketing off. It happens not very often, so I wonder if my finger might be a bit trigger happy. Combined with a sensible button, this may be the cause. Oh dear.
1 Day Ago - 1 Like   #10
A peek at the makernotes in the EXIF would indicate both bracket and drive mode as would opening the file in the Pentax DCU software.
1 Day Ago   #11
BigMackCam's Avatar
I had a similar issue to yours on a few occasions some years back. I can't remember which camera, now... I think it was my K-5 or K-3. I found it happened when I pressed the edge of the shutter button rather than pressing down directly and deliberately on the centre of it. The result was kind of a light rocking motion on the switch, creating occasionally intermittent contact. It took me a little while to consciously retrain my forefinger, but it apparently worked as I've not had the problem since.
Might be worth testing this to see if it's the cause in your case...
1 Day Ago   #12
Yeah, good point, will have an eye on that. Maybe it's like you described.
camera, fires, frame, ii, k1, k1 mark ii, mark ii fires, mode, pentax help, pentax k1 mark, photography, troubleshooting
For Sale - Sold: Pentax Battery Grip D-BG6 for K1, K1 Mark II tscip22 Sold Items 2 09-27-2019 01:56 PM
K1 to K1 Mark II or not II Kingman Pentax K-1 39 03-07-2019 10:09 PM
Pentax K1 or Pentax K1 Mark ii giselag Pentax K-1 15 01-04-2019 01:36 PM
shutter fires twice in single shot mode??? shang Pentax K-5 7 07-02-2012 11:26 PM
Shutter only fires sometimes with manual lens - sears 50mm f1.7 jptruesdale Troubleshooting and Beginner Help 4 10-11-2011 08:16 AM
All times are GMT -7. The time now is 09:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
