Originally posted by ehrwien Is there any info how bad it is in case of the K-1?
The only info I could find on the Electronic Shutter in the K-1 was:
It is meant to be used for perfectly still scenes.
How bad it will be will depend on how far you push the limitations.
---------- Post added 09-18-20 at 07:04 PM ----------
Originally posted by Gerbermiester I can't seem to get my AF540FGZ flash to fire while in electronic shutter mode. But, in mechanical shutter mode, the flash works no problem. Anyone know if this is normal behavior?
Yes.You cannot use flash with ES. I seem to remember the scan time for the ES is around 1/10 second. There is your problem. There is no single moment in time when the entire sensor is recording
