I picked up a pentax bundle in an Ebay auction a while back: The main item of interest was the lens in question:
170-500mm 5-6.3 APO (not DG)
This is the one:
Sigma 170-500mm F5-6.3 APO Lens Reviews - Sigma Lenses - Pentax Lens Review Database
TLDR: Head to last paragraph for questions.
Opening the bundle, I found everything was immaculate (as in next to no wear or scuff marks) so that was great! The 170-500 was filthy on the front lens, so I waited for a cleaning kit to arrive, but I could see a spot of fungus on what appears to be the second element behind the front glass. Am I worried about the fungus? Yes and no, it's not ideal, but it's not a lot and research shows it often wont make noticeable different for a casual (ie: me) photographer.
But what was exciting, was mine didn't appear to suffer the zoom creep that everyone complains of.
--At first--
After extending the zoom back and forth a few times, it become evident that this gear has been sitting idle for a very long time (it was bundled with a Z1-P 35mm, which is immaculate, might give it a spin some day), and then yes, zoom creep is definitely there. I'm not upset, that was to be expected.
But the focus ring is stiff, noticeably more at either end, and worst at infinity. I didn't think much of it.
Put it on my *IST DL2 (that's the only pentax DSLR I have) and went to line up my first pic..... and the focus ring doesn't move... Drat.
So slip it into MF, go max zoom down the hill towards the air port, manually adjust to the best of my ability, and take a few quick snaps: The IQ is ok, I tested just in auto, with a (now clearly evident) too frail of a tripod, and un-image stabilized body: I'm sure with a stable tripod, and a faster shutter, on a bright day it will be fine for me. [EDIT: Added these questions] I believe this is a full frame lens, so that makes it 500m * 1.53 =765mm equivilent at full zoom? I wonder if this is partly why so many complain of it being soft?
So, the question is: What do I do about this focus ring? Zoom creep is evident, but the zoom isn't super smooth either, the aperture ring is sweet, free as a bird. Any suggestions welcomed: Do I operate it manually for a while, see if it frees up? Leave it in the sun, see if heat can 'release' some lubrication? Is there some secret opening under the rubber band I can drop a lubricant on? Or am I simply out of luck, and need to look at stripping it, and cleaning the fungus while I'm at it?
PS: I set up a dry box.... but here in Adelaide, so far, even without any desicant, the humidity hasn't risen past 55 in the box, so I doubt fungus will be a problem for me (in typical use).
Reason: Added extra questions.
