09-19-2020, 06:37 PM   #16
maw
maw's Avatar
QuoteOriginally posted by Pentaxis Quote
Sorry, I referred to your name in previous comments as Antonio rather than your correct name, Mario. I must have been thinking too much about the problem :-).
Actually you guessed wrong Antonio is my middle name, ahahah!
The important thing is that you succeeds in one way or another to solve the problem.
Ciao Mario
09-20-2020, 01:51 AM   #17
Astro-Baby's Avatar
Drilling will be an absolute last resort, the base is plastic only and will be marred very easily, its quite a soft plastic.
Unusual as I have repaired a lot of X series, and yes the XD was probably the last with metal casework, and usually the screws come out easy. JIS drivers are a must though. I have never seen it on a body but I have seen the odd lens that has had a factory applied lacquer applied in the threads to make them grip and they can be hellish sometimes to remove. IPA is ever your friend, a hot hair dryer given a quick blast on it may be sufficient.
baseplate, camera, efforts, head, heads, heat, model, oxidation, pentax help, photography, plate, pm, post, precision, screw, screwdriver, screws, screws stuck, slr, suggestion, thanks, threads, tool, troubleshooting
SP 1000 stuck mirror - clean and oil lock mechanism in the baseplate? jaymoussy Troubleshooting and Beginner Help 2 11-19-2019 01:14 PM
PK-M 50/1.4 ring stuck, back-plate screws stuck fungiman_md Troubleshooting and Beginner Help 4 05-10-2011 12:54 AM
Manfrotto baseplate interchangeability Derridale Pentax Camera and Field Accessories 1 04-24-2010 01:24 AM
K10D Rubber Cover off baseplate lost ripleyfrog Pentax DSLR Discussion 5 11-02-2008 01:55 AM
All times are GMT -7. The time now is 08:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
