Originally posted by termy thanks for the candid sharing, Sharky and everyone.
All things considered (and that's quite a number of factors), it will seem that it does not quite make sense to go for a K-70.
1) Ricoh will use back that same flawed part when users send in the K-70 for repairs. This alone makes it kind of pointless.
than pursuing the outside possibility of aperture control failure
2) I am not a technically minded person and thus, not likely to be able to self-replace it. Which means, going to Ricoh and knowing they will use back that same flawed part.
3) no doubting the capability of the K-70. But point number-1 above, negates this.
4) where i am, dont think there is option of extended warranty.
But even if there is, point no.1 above makes it somewhat pointless.
How many years of extended warranty could one keep getting anyway.
5) it might be so that incidents of K-70 having that "black death" syndrome is much lesser than the other K-x0s, but maybe that's because K-70 still relatively new.
But i am hearing more incidents of K-70 having this problem.
6) so, it will either be a KP or wait for the K New (but then, the issue of lack of flip screen comes up, but no, i have seen the heated debate on this and will therefore not say much, other than, i belong to the camp that still thinks Ricoh's explanation of it, doesnt have much substance behind it, if at all any. Yes we accept that the K new will be fixed screen, but no, dont buy the explanation, not when too many other aspects of the whole K New thing doesn't quite gel with the reason/s given [to me, at least]).
Will think it through.
I did think it through, and I purchased a KP during "Black Friday" 2018 sales; I am certainly not regretting it.
One factor which you should consider is the failure rate of the K-70's aperture control.
stevebrot and I disagree over what that rate is - I think it is higher than he does. At current prices I cannot recommend a K-70 instead of a KP, and when problems were recently reported with a K-70 it was the first thing I thought of even though he said another possibility made more sense "
than pursuing the outside possibility of aperture control failure". However, while a person might expect to send a K-30 in for repair every few years, I believe that aperture control of the K-70
has reached the point where it will fail sufficiently seldom that you may not have to send in a particular unit for that particular repair more than once in a reasonable lifetime {it
is still a consumer-grade product, so I would expect less than ten years to pass before all the pieces need replacement under normal consumer use},
and you always do have the option of using it with "F" or "FA" lenses which do provide both AF and aperture control at the lens - in fact, even though a KP is now my primary camera, I did get a FA 28-105mm, so I can continue to use my now five-year-old K-30 on occasion {silver lens on blue camera in my signature photo}.
