09-21-2020, 01:13 PM   #1
Spodeworld's Avatar
Shooting in Bulb mode
Hi - There doesn't seem to be a place for K20D questions any more (I still use it for some reason). Unlike my K3, I can't seem to find a setting for when I'm in bulb mode so that I can press the shutter once to open it and a second time to close it. Are there any K20D users who know if that is available on the camera?
Thanks
09-21-2020, 01:46 PM - 1 Like   #2
Alex645's Avatar
What you are referring to is found in the K-1 as the 'bulb timer' mode. Or with the K20D you could use the Pentax Remote Control F for a one press to open during bulb and one press to close.
Without the remote on the K20D, bulb requires that you depress the shutter release button for the duration of the exposure as is explained in the manual on page 96:
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k20d.pdf
09-21-2020, 01:56 PM - 2 Likes   #3
maw
maw's Avatar
QuoteOriginally posted by Spodeworld Quote
Hi, I have too the glorious K20D, "if I understand correctly" you would like to press the button to make a long exposure at will and then press the button again to close it?
Unfortunately even from the menu this possibility does not exist.
You can only equip yourself with a flush control like the original CS-205, ''or a similar one'' that allows you to snap and lock the shutter with the switch for as long as you want, this is feasible.
Ciao Mario
09-21-2020, 03:59 PM - 1 Like   #4
35mmfilmfan's Avatar
This may explain the derivation of the term :
Bulb (photography) - Wikipedia
09-22-2020, 10:15 AM   #5
Spodeworld's Avatar
OK, I suspected it wasn't there in the menu. It is for the K3, but it looks like I just have to have the remote shutter depressed as long as I want the exposure for - there's no menu option to press once to open and once again to close.
QuoteOriginally posted by maw Quote
Ciao Mario
09-22-2020, 10:43 AM   #6
maw
maw's Avatar
I bought the original CS 205, but it is not essential, you can buy one that has the wire and can lock the button, instead of the wireless ones, which are equally useful but not in this circumstance.
I'll put you links just for clarity, Cable Switch Or on Ebay.
bulb, camera, k20d, mode, pentax help, photography, troubleshooting
Bulb mode confusion?? Larrymc Pentax DSLR Discussion 10 12-02-2019 07:20 PM
K-3 BULB MODE issues on Firmware V1.11 V1.20 V1.40 gedasst Pentax K-3 & K-3 II 8 01-16-2019 02:04 AM
Pentax K-3, Manual Mode won't switch to Av, Bulb, but stays in M Mode scotman55 Troubleshooting and Beginner Help 3 12-05-2015 08:39 AM
Is is possible to have a wirelessly activated bulb mode / interval shooting? Conqueror Pentax DSLR Discussion 7 04-20-2015 01:48 PM
Shooting in Bulb mode. JD44 Pentax K-5 & K-5 II 7 10-24-2012 01:22 AM
All times are GMT -7. The time now is 10:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
