09-28-2020, 04:31 PM   #1
kcjonez's Avatar
K-3 card access light blinking when camera is off
The orange card access light (to the right of 4-way controller) is blinking non stop on my K-3 when it is turned off. It stops when I turn the camera on which must mean nothing is being written to the card. It stops when I remove the battery or cards. I tried two new cards and it continued blinking.
Anyone got any ideas why this is happening and how to make it stop?
09-28-2020, 05:07 PM   #2
jatrax's Avatar
Aside from the blinking does the camera take images and more importantly write to both cards? I'm just guessing but that is the card access light so maybe one of the card slots is bad and the camera keeps trying to read that card but can't?
09-28-2020, 05:08 PM - 1 Like   #3
maw
maw's Avatar
QuoteOriginally posted by kcjonez Quote
This is abnormal, it should be the opposite.
Anyway similar problem happened this summer, I was doing some tests on K1, the read/write light remained on even after turning off the switch went off after a long time.
It could be either 'overheating' or a corrupted 'file system'.
- You can try to reverse the cards to see if the problem returns or disappears.
- I fixed it by copying all the photos from the card and then I reformatted it, even if this doesn't work, it could be a defective card.
- You can format it eventually in a card reader in your computer and then insert it in the slot of the K3.
Let us know if the problem remains.
Ciao Mario
09-28-2020, 05:09 PM   #4
Aaron28's Avatar
really don't........i know it will blink very temporarily when placing a card in the slot(s) when turned off but not continuously there after.......
wonder if debris is in the slot........
09-28-2020, 05:30 PM   #5
Not a Number's Avatar
Since you tried new cards we can for now concentrate on other areas namely the card slots.
As suggested above check to see if there is dust or other debris in the slots. Perhaps blowing out with a squeeze bulb blower. Also see if any of the contacts are bent. It may be difficult to see some of the lower contacts as they are double rowed.
Does it behave the same with only one card (check either slot)?
09-28-2020, 06:04 PM   #6
kcjonez's Avatar
Affirmative. No issues with taking or transferring files.
---------- Post added 09-28-20 at 09:06 PM ----------
Interestingly, the light only blinks one blink at a time when only card #1 is installed. Blinks double blinks when card #2 or both cards are installed.
Strange.
Have blown out card slots with no change. Maybe a little alcohol on a toothpick or somesuch?
09-28-2020, 06:31 PM - 1 Like   #7
jatrax's Avatar
Last resort only I think. Those little contacts are very delicate. I wouldn't touch them.
- format cards in the camera?
09-28-2020, 07:38 PM   #8
Otis Memorial Pentaxian
This is how my K-3 behaves.
Camera off, both cards out, single card on insert:
Slot #1: blinks x2
Slot#2: blinks x1
Same as above two cards:
First card, slot #1: blinks x2
Second card, slot #2: blinks x3
First card, slot #2: blinks x1
Second card, slot #1: blinks x3
Turning camera ON:
Single card either slot: blinks x1
Two cards, slot #1 loaded first: blinks x2
Two cards, slot #2 loaded first: blinks x2
(...suspects blink count is a red herring...)
09-29-2020, 03:43 AM - 3 Likes   #9
kcjonez's Avatar
Update;
I left both cards out last night and card slot door open. Reinserted cards this morning.......no blinking lights!?!
Suspect moisture may have been the problem. Yesterday was a wet day for the old K-3.
Thanks to all for feedback!
PENTAX K-3  Photo
09-29-2020, 08:31 AM   #10
jatrax's Avatar
Thanks for reporting back. Always good to collect another tidbit of information.
access, camera, card, cards, check, contacts, installed, k-3, light, pentax help, photography, slots, troubleshooting
KS2 Blinking Bracket Indicator retpgmr Pentax K-S1 & K-S2 2 03-09-2020 05:18 PM
K20D - Slow review, Card Access Light on Mike Gallagher Pentax DSLR Discussion 4 03-06-2015 08:14 PM
K-5 timer light blinking Harry42 Pentax K-5 & K-5 II 4 01-06-2014 01:59 AM
blinking red light on my AF-540FGZ juicebox Pentax Camera and Field Accessories 4 07-21-2010 03:24 PM
For Sale - Sold: Tamron 75-250mm, Access 35-70mm f/2.5-3.5, Access 70-210mm f3.5, Kenlock 80-20 hinman Sold Items 14 03-20-2010 12:25 PM
All times are GMT -7. The time now is 05:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
