Originally posted by dipo 1 Wow have I got a lot to learn and read, I have a K5. Think Ill shoot jpeg awhile till I learn more about my camera. GREAT BIG THANKS TO ALL OF YOU!!!!
You have an excellent camera! I hope you have a fine and versatile lens also.
When it was a current model, the K-5 was the finest DSLR camera Pentax made- the "Flagship" model, designed for advanced and professional users. In addition, it won awards for originality and performance and was top-ranked by independent testing labs specializing in camera equipment. It was also a very significant advancement in performance over the previous Pentax flagship model.
I would advise not using the green "Auto" setting on the mode dial. This setting will not allow most adjustments or access to many features, having the camera make all decisions and settings according to what it "thinks" you are shooting. To shoot with fully automatic exposure, where the camera will set both your lens aperture opening and the shutter speed for "correct" exposure according to the camera's light meter reading, use the "P" (Program) mode instead, which will allow adjustments, etc. In fact, though this is a standard setting for any brand of DSLR, with Pentax you can access more adjustments than others.
You can also experiment using the "Av" (Aperture value) mode, where you set the lens aperture and the camera sets the shutter speed accordingly for "correct" exposure. Or "Tv" (Time value) where you set the shutter speed and the camera will set the aperture. However, the purpose for each of these settings and when to use them for what purpose is for another discussion. There are also other, more advanced modes.
You can and eventually should also learn to shoot in the "M" (Manual) mode where you set your own choice of aperture and shutter speed according to the meter reading you observe in the viewfinder or LCD panel.
So, first thing- set your mode dial to "P" then notice the 4 buttons surrounding the "ok" button on the back of your camera. Press the button to the right of "ok" which will open up the Custom Image menus. Now the 4 buttons will be for navigation. By default, the category the camera is operating with and should be shown is the "Bright" category. If not, navigate to that category. Once you have it, navigate down to the Sharpness aspect for adjustment. By default, "Bright" will have sharpness increased up one notch. Increase that by one more notch using that right-hand button, which with this model camera can be done without introducing unwanted effects. Now also implement "Fine Sharpening" using your thumb dial to put an F by the S. Then hit "ok" and you are set to go.
