Originally posted by Not a Number
The rule of thumb is the slower the lens the darker the viewfinder at wide open. Thus the "graininess" becomes more apparent.
This ^ ^ ^
Originally posted by Shadwell59
Thanks people. Are you saying that even on a high quality lens I'm still going to see this and the answer is not to use a longer length than I actually need if I want to use the viewfinder?
See answer above. With lenses having a narrower maximum aperture, the amount of light to the viewfinder is decreased and the view is dimmed. A side-effect of that dimming is that the matte field appears grainy. At f/3.5 (the wide end for your lens) the view should usually be fairly bright, but f/6.3 at the long end is quite a bit dimmer (almost 1/4 the light).
