Originally posted by goldendeerboi13 Hello, here are the photos I took of the camera's internals. What do you think?
It's a bit hard to see clearly in there from the pictures, but I can't discern any yellow gunk. You should be able to tell better for yourself by looking in there with a flashlight. Try shining the flashlight through the viewfinder and then looking at the focusing screen from inside the body (backlighting the screen). That might show up any dirt on the top of the screen. If it's clean, have you tried Sharky's suggestion of cleaning the diopter lens? If none of these, then it's likely a desilvered prism mirror. In any case, none of these things will affect your pictures, and it's just an annoyance (which hopefully isn't so bad that it prevents you from using this camera).
Hope you get it sorted. The KX is a nice camera!
