Originally posted by pschlute That is not correct. Whatever lens you use (even M or K lenses) EC will have an effect with the K1 in Manual mode. Dial in +5 EC and press the green button or use the DOF preview lever method to centre the exposure meter, and you will have an overexposed shot by 5 stops.
Now that you said I'm not correct, I just tried it instantly again.
Result from a few minutes ago:
K-1 and M1.7/50, M Exposure Mode - Green button + 5 EV comp delivers the same image as green button without EV comp.
Believe it or not.
If I reduce Exposure Time I get an underexposed image, if I put 5 stops on top I get it overexposed. That's how it should work.
So maybe our K-1's are different? Or there is a parameter that makes it work this or that way?!
How knows. I just reported how my K-1 behaves.
The important thing is that everyone knows his own kit, so that it works how he/she expects. Testing by ourselves is essential and helps to learn.
