Originally posted by colinkp I've recently upgraded from a K50 to a KP.
When I try to adjust the white balance, for example, I need to put the camera into live view before the screen shows the options. I didn't need to do that on my K50 as I just pressed one of the 4 buttons around the OK button and the screen changed.
The manual just says to have the camera in standby and doesn't mention putting it into live view first.
Is this just how it is done on the KP or is there some sort of fault?
Thanks
I am wondering, did you purchase your KP used? I've been using mine for over two years and have never experienced this issue.
---------- Post added 10-30-20 at 05:20 PM ----------
Originally posted by pschlute He just needs to activate the rear screen guys. Please stop complicating things.
I'm thinking this must be the case. The camera comes new with the rear screen activated when not in LV. I have never turned my rear screen off to extend battery charge or for any other reason. The display comes on immediately after turning the camera on. The buttons for ISO adjustment, etc are right there on the back of the camera, and using the appropriate button brings up the menu for those adjustments. It is all very quick and easy. Unless the mode dial is set to the Manual mode, the ISO screen also allows to either have automatic ISO setting by the camera, and you can set the ISO range for this, or you can switch to manual ISO so you can then set your own choice.
Incidentally- to the OP:
I strongly recommend not having your mode dial set to "AUTO" as this will disallow making most adjustments and will make many controls unavailable. It will also deny access to the wonderful, exclusive Pentax Hyper System. Use the "P" (Program) setting instead for fully automatic operation of shutter speed and aperture for proper exposure. Then, the Hyper System is activated, so you can override the camera's choice of shutter speed or aperture just by selecting your own choice by simply using the thumb or finger dials, without having to change the mode dial to Tv or Av first before making your selection. Then you can restore full automation to "P" with a touch of the green button.
If shooting high-quality JPEG images right out of the camera, the KP's processor is exceptional for excellent results. Just be sure to implement "Fine Sharpening" in the Custom Image menus, especially in the most often-used "Bright" setting. To access, use the "info" button for the quick access menus. At that point, the 4 buttons around "ok" are for navigation. If running into any problem doing this or for any other issue, don't hesitate to ask.
