Originally posted by Brathahn I would say you should try and spend some time getting to know your camera better, it can and will provide good pictures if you know how but taking a picture is no rocket sience!
I agree with this- except there is a lot more to it than shooting in the "AUTO" mode, which should be avoided. That mode disallows access to many adjustments and will choose its own Custom Image processing according to what it "thinks" is right for the circumstances of your scene, etc. You lose virtually all control, and control is a primary advantage of having this type of camera. If you want full automation by the camera for shutter speed and aperture for "correct" exposure, use the "P" (Program) mode instead, which allows access to all functions, including the exclusive Pentax Hyper System. In the mode, if you a not satisfied with the shutter speed or aperture the camera has chosen, simply enter the Hyper System by selecting your own choice simply by using the thumb or finger dial, without having to first turn the mode dial to Av or Tv. Then, to return to full "P" operation, a touch of the green button will instantly restore it.
But do learn how to use the Manual mode better, and take your own meter readings of a scene. Very important in taking advantage of the advanced nature of your equipment. Spot metering can be very valuable in dealing with tricky lighting that can fool your other metering types.
100,000 shutter actuations was the old standard for professional film cameras. The K-S2 is quite good for higher ISO performance with minimal noise- I'd say up to and including at least 3200. Of course, it depends on whether you are seeking the lowest noise possible.
I don't see any real problems with the images examples you have posted. I assume you hare using a tripod with such slow shutter speeds. To get certain effects, there is no better way.
