Folks, I am in need of serious help in getting usable images from my K50.
As I posted recently, in a question concerning bird photography, I am new to the forum, and I quite some time ago bought the K50 to able to use older Pentax lenses from my film camera days.
The lenses are a 50 and 70-210 SMC-A, a 28 SMC-F, and a 100 SMC-M.
My intent was to learn to use the set up in totally manual mode. I could never get correct exposures, got frustrated, and put the camera aside; the set-up just acted "weird".
Every once and awhile I'll give it another go. Today I decided to try the simplest thing possible, shoot in Auto Mode with the 50 lens. It was bright and sunny out, and I took it for some shots in the backyard. No go. Using the eyepiece viewfinder, on review I was getting totally black images. Using the live viewing screen monitor, I get an image upon review, but way dark and under exposed.
When the camera is first turned on, as should be with the A lens, I pick and OK the 50 mm lens length on the view screen.
The side switch is on MF, as this lens does not autofocus. The lens is set to "A" on the lens f stop ring, per the manual.
Mode is Auto.
I hope this is user error, what I am doing wrong??? I hope it is not the camera body, as I've had it too long for warranty I would believe.
To say I am frustrated with this set up is a huge understatement.
At this point it is totally unusable, and nothing more than a somewhat expensive paper weight.
Any insight would be greatly, greatly appreciated.
