11-13-2020, 08:06 AM   #1
Pentax 645z NOT turn on
Dear Friends
I'm facing this issue with my Pentax 645z not turn on at all even though the batteries are fully charged when I turn it on only the indicator of the battery shows full then disappears with green light of the display appears for less than a second the all off
any suggestion for me to do to over come this problem as well there is NO Pentax service agent to send it to
Regards
Saeed
11-14-2020, 09:46 AM   #2
Denver's Avatar
HI
I would first get a fresh new battery, charge it. A battery will show full charge but not take a load.
11-14-2020, 09:52 PM   #3
QuoteOriginally posted by Denver Quote
HI
Thanks Denver I already ordered batteries BUT I do have two old batteries and both doing the same (CAMERA NOT TURNED ON) will sure keep you posted when i try the new batteries have a great day
11-16-2020, 11:23 AM   #4
Sounds like your camera needs to go in for repair. FYI note that most 645D/645Z repairs require shipping to Japan.
11-18-2020, 12:02 AM   #5
QuoteOriginally posted by K6-III Quote
Good morning
true even with the new battery NOTING still cant operate the camera unfortunately will find a way to send it to JAPAN and fix this issue thanks
11-18-2020, 09:36 PM   #6
HI
good morning solution found by coincidence when i removed the memory card the camera worked actually reason card was corrupted NOW all good with the camera both 1 and 2 was corrupted cards so please if anyone faces the same issue look in to removing the cards also and change it might be the same what i faced have a good day
---------- Post added 11-18-20 at 09:37 PM ----------
QuoteOriginally posted by Saeedaljaberi Quote
11-19-2020, 07:40 AM   #7
Glad to hear that it was just a memory card
645z, batteries, camera, card, cards, change, charge, coincidence, issue, morning, pentax, pentax 645z, pentax help, photography, reason, solution, troubleshooting
Pentax 645z doesn't turn off maxloxton Pentax Medium Format 7 09-13-2020 04:13 AM
645Z - turn off the self-timer? RobertM Troubleshooting and Beginner Help 3 02-11-2016 02:06 PM
Nature ...there is a season, turn turn turn... littledrawe Post Your Photos! 4 09-19-2012 11:57 PM
turn left turn right... err no jeffkrol General Talk 33 04-19-2012 09:19 AM
To turn right or to turn left spura Pentax SLR Lens Discussion 14 04-15-2009 11:29 AM
All times are GMT -7. The time now is 06:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
