11-15-2020, 03:31 PM   #1
Fungus? Worth fixing?
I have an Auto Rikenon 28mm f2.8 with what appears to be fungus on one of the rear elements. Is this an easy fix? Is it best to strip it from the back? And what is the best cleaning solution? I have never done this so any help or guidance would be well received. It has really good reviews on PF, otherwise I wouldn't bother but I am not an engineer, so, heeeeelp
11-15-2020, 03:48 PM - 5 Likes   #2
Sandy Hancock's Avatar
Put it in a sealed bag, and burn it
11-15-2020, 03:53 PM   #3
That is vying to be option 1 I have a nice chinon 28mm (the super sharp one) and a tokina that is a gem. I also have a soligor 28mm made by sun so I wouldn't miss the rikenon, but, if it as good as the reviews say .....
11-15-2020, 04:59 PM - 1 Like   #4
Emperor and Senpai
VoiceOfReason's Avatar
If you already have 28mm lenses what's to lose in trying?
11-15-2020, 05:07 PM - 1 Like   #5
ramseybuckeye's Avatar
If you do, make sure you have JIS screw drivers or you will damage the screw heads. Have some way to keep the screws in, magnetism works well. The screws are tiny. take pictures of each step. You may need a spanner. You need a well lit work table. Good Luck!
11-15-2020, 05:17 PM   #6
ismaelg's Avatar
If you decide to try it (and I encourage you to), carefully disassemble from the back noting the orientation of the parts as you take them out. Once you get to the offending glass use Hydrogen Peroxide liberally. It may not get back to mint if there is some etching but it will improve. Make sure it is clean and dust free with a microfiber towel and put it back together.
*EDIT* As noted before, JIS screwdrivers are a must. Regular cross point may work but you risk stripping the screws.
Thanks,
11-15-2020, 05:39 PM   #7
I would try to clean it myself. Nothing to lose. There all several quality 28/2.8 lenses available at a good price.
11-15-2020, 11:35 PM   #8
Michail_P's Avatar
What about UV? I’ve heard of this, doesn’t it work?
11-15-2020, 11:55 PM   #9
QuoteOriginally posted by VoiceOfReason Quote
Thats true
---------- Post added 11-15-20 at 11:56 PM ----------
QuoteOriginally posted by ramseybuckeye Quote
I have a big rack of jis screwdrivers that I bought but barely use, time for a play
---------- Post added 11-16-20 at 12:00 AM ----------
Thanks,
It looks quite faint, I am hoping this means it is at the early stages, although there is a possibility it has been cleaned and what I am seeing is etching and not fungus. The operation of the lens is suspiciously buttery smooth lol. I need to buy some hydrogen peroxide. Where to get that during lockdown. Hmmmm. Thanks
---------- Post added 11-16-20 at 12:01 AM ----------
QuoteOriginally posted by DWS1 Quote
That's the way I am heading. Worst case, I get some practice at stripping and reassembling
---------- Post added 11-16-20 at 12:02 AM ----------
QuoteOriginally posted by mixalis_kalymnos1611 Quote
I think that works at killing fungus, say when you have a little bit that doesn't affect image quality, but in this case it needs cleaning
11-16-2020, 12:20 AM - 1 Like   #10
Just wipe the fungus off with a bit of condensation (breathe on it) and a clean cloth. No need for any fancy chemicals.
For a lot of lenses the front and rear elements are separated by the aperture blades, so if your fungus is in a rear element then you need to disassemble from the back. When you open it up you might ne able to move the aperture blades out of the way using the lever in order to clean the rear surface of the front element group.
Just start at the back with a lens spanner and make your way through the lens. Reassemble the rear elements and then start from the front if there is still some fungus left over.
11-16-2020, 12:22 AM   #11
Astro-Baby's Avatar
Dont know the lens but would guess a lens spanner will be needed.
With luck the rear lens will unscrew in one block but you will need to get a lens spanner on it.
Once out the approach would be just a drop of hydrogen peroxide and wipe gently with a cotton bud. Flush lens with water and blow dry and final polish with lens cloth.
If its a cemented double go very easy with it and dont immerse it in anything.
11-16-2020, 02:07 AM   #12
ZombieArmy's Avatar
I mean what do you have to lose by trying I say.
11-16-2020, 02:13 AM   #13
QuoteOriginally posted by HarisF1 Quote
I like the idea of trying a good wipe first before hitting it with chemicals I can do that now, and if it doesn't work, I will go shopping
---------- Post added 11-16-20 at 02:15 AM ----------
QuoteOriginally posted by Astro-Baby Quote
Thanks I have unscrewed the rear ring that needed an improvised lens spanner but that just gave me the rear element bi need to get my screwdrivers and get the mount off
---------- Post added 11-16-20 at 02:16 AM ----------
QuoteOriginally posted by ZombieArmy Quote
Nothing its currently a paperweight and whatever I do, it will still be a working paperweight lol
11-16-2020, 02:24 AM - 1 Like   #14
ZombieArmy's Avatar
QuoteOriginally posted by Cerebum Quote
That's the spirit!
11-16-2020, 02:29 AM   #15
Take pics as you go please. It will be a learning experience for me anyway.
ammonia, camera, chemicals, cloth, dont, etching, fungus, hydrogen, jis, lens, lenses, paperweight, pentax help, people, peroxide, photography, post, quality, screw, screwdrivers, screws, spanner, thanks, troubleshooting
ZX-50 with mirror-block issue - worth fixing? cdw2000 Film SLRs and Compact Film Cameras 7 08-14-2020 06:39 AM
Is it worth fixing/cleaning on this Tamron 55BB 500mm f/8.0 mirror hinman Pentax SLR Lens Discussion 26 10-09-2017 07:04 AM
Is an old Spotmatic worth fixing? BB_Zone28 Repairs and Warranty Service 10 06-09-2017 10:30 PM
Decentered DA 16-50, worth fixing? ruggiex Repairs and Warranty Service 5 05-25-2017 03:13 PM
Lens worth fixing? kc.virginia Film SLRs and Compact Film Cameras 17 02-17-2013 02:55 PM
All times are GMT -7. The time now is 11:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
