Originally posted by Papuchalk When looking at last picture, which is still in the memory, there should be option to save the JPEG file into RAW with AE-L.Button.
If the JPEG was the file save type, last photo taken should have the AEL-save-RAW icon visible at upper right in playback mode. However, the file save type cannot be RAW+ and the camera cannot have been shut off or gone into sleep mode since the photo was taken.
Originally posted by Papuchalk This should be also available in quick view, if this setting has been chosen to appear (which i have set to YES)
If the feature is enabled (menu --> rec. mode 4 --> Instant Review --> Save RAW Data --> enabled...default) the icon should be present. As with the similar feature in playback mode, the file save type must be JPEG, not RAW+.
This feature works on my K-3 (checked just before typing this comment) and should work for you too.
