Originally posted by Theob24 I was wondering if it is normal for the focusing system to feel jammed only at around 35mm (at 18mm or 55mm it works great: no problem)
No, it's not normal. There is something damaged in your lens, but as others said it, it's not worth repairing. Even if with the K5, you probably got a 18-55 AL II or 18-55 WR ; both are better optically than the original 18-55 ; but you have many lens options, all better than the Kit.
Do not hesitate to post a topic in this forum :
Pentax SLR Lens Discussion - PentaxForums.com and we will tell you what you
need. Do not forget to mention budget!
