Originally posted by photogem
If you remove the spring (tiny screw) and then screw the adapter tightly onto your lens, the adaptor will not lock in the usual position but move further (about 1/4 turn)
and thus the rear of the lens assembly will be closer to the sensor:
Sorry, but I don't think so, at least not with the Mamiya/Sekor or the Rikenon. I work a lot with adapted M42 lenses. With the genuine adapter, it goes as follows...the adapted lens will engage the K-mount and that is as deep as it goes. Such may not be the case with the Helios 44-2. IIRC all Helios 44-2 variants have a narrow mount flange that engages most M42 bodies, but does not engage the wider-opening K-mount. As a result, they work better with brand-X adapters that sit flush or with flanged adapters; though with any non-flanged adapter, there is potential for light leak at the two adapter "notches".
(...My Helios 44-3 is similarly narrow-reared and I use a thin flanged adapter with it...)
