The shutter and winding mechanism are two different things, but they are inextricably linked in operation: the shutter will not fire a second time unless the frame is wound on (exception: those Pentax 67 cameras with factory-fitted multi-exposure facility available). As Phil, above stated, dry firing requires a bypass key in order to test and observe the shutter action without using any film.
I am inclined to think the camera has been set aside too long with the shutter cocked, leading to laziness of the magnet. There is an advisory of sorts about this in the 67 owner's manual, additionally to storing the camera with the shutter speed dial on any setting other than a marked shutter speed or X (Bulb is fine); storing the camera with the dial on a shutter speed can also lead to inaccuracy of that or other speeds.
Prolonged cocked, idle setting can cause the shutter magnet to stick. This can manifest as either the shutter randomly failing to fire, or firing intermittently (even an entire roll being exposed), giving the impression there is nothing wrong, but which highlights an uncomfortabel truth: it obviates a degenerative problem that will eventually require repair.
High temperatures present their own problems. Where I am it is regularly 45°c in open shade, and nobody goes out there, nor the dogs! I never use my own cameras in +40°c heat; doing so can melt the seals around the camera pack, the prism, distort the focusing screen and as you have been told, affect the internal lubrication, which is miniscule in quantity, abundant in application, and essential for smooth function. It's like clockwork inside a 67!
As much as I would like to agree with the seller's statement to you, I don't.
A brute test is worth doing at this stage to be suss things out.
Grab a couple of rolls of cheap film, and whip these through the camera using as much continuous shooting as you can. During this test if you notice the shutter is not firing or firing intermittently, the proof is there that a fault exists. If you cannot get it to fire again after noticing the stop, unload the film (release both base clasps, open the back and remove the film, avoiding any contact with the shutter), and that is the end of the test.
If that test of 2 rolls has had to be aborted, then I would recommend the camera be returned to the Seller on the basis that, in my view, you are looking at a degenerative fault that is not a once-off, but going to become progressively worse in time.
