Originally posted by Jonathan Mac For the weekend I've been charging a set of Eneloops, leaving them in the camera for a few hours and then charging them again and putting them back in the camera, in the hope that the capacitor will charge up again and allow it to work. So far no luck. It will allow a few shots with fresh batteries, and shows them as full, but then refuses to switch on again, blinking the battery icon on the display.
Jonathan, I started with a fully charged set of Eneloops as well, and had the camera’s meter shut-off set to one minute. Every time the meter display in the top LCD shut off, I immediately switched the camera off & back on (even if only the dead battery icon was being displayed), and did this over & over again - probably fifty times or more, with no stopping to recharge the batteries. Eventually during this process, the battery icon started reading half full, and then full the majority of the time, but the readings still did shift around a bit. At that point I fired off a few test shots & it held well, so I then switched the batteries out for a brand new set of Energizer Lithiums & continued to fire off many more shots, including with flash. The camera had now returned to normal functioning & consistently gave a fully-charged battery reading. If I were to do it again, I’d probably just start with the Lithiums rather than the Eneloops, as I believe they’re more reliable in their output.
Edit: Of course this is all armchair guesswork, but I'm thinking the key point of the process is to hit the capacitor over & over again (in one minute intervals) with a fresh jolt of power - in essence, to shock it out of it’s dormant condition.
Edit #2: This probably didn't really make a difference, but I'll mention it just in case: In the menu settings, there's an option to direct the camera to prioritize batteries either in the body or grip, or to auto-select (default). I set the camera to prioritize the batteries in the body (in order to perhaps help facilitate the camera more directly linking with the batteries).
Hoping this will help & your camera begins working properly again..... Bob
