12-08-2020, 10:03 AM   #1
HELIOS-44M front focusing.
I enjoy photographing with the HELIOS-44M on my K-5. But I have noticed that it is slightly front focusing from the view finder. I mean that when I see the subject perfectly focused in the view finder and the red rectangle glows momentarily with the confirmation hexagon continuously lighting, when I switch to Live View and magnify up to x10 the image needs just a tiny turn of the focusing ring towards the infinity to achieve perfect focus. At the menu feature number 26 'AF Fine Adjustment' there is only the 'Apply All' option. What should I do?
12-08-2020, 11:11 AM   #2
Otis Memorial Pentaxian
QuoteOriginally posted by Hidrieus Quote
If you only require a tiny nudge at 10x live view with positive focus confirm, that is much better than expected. I would do nothing. FWIW, 8x is probably closer to 100% (1:1) on the K-5.
12-08-2020, 12:29 PM   #3
It's probably because "AF Fine Adjustement"... is for auto-focus lenses, and the Helios 44M is not.
For what you said, I would not worry. In my experience, autofocus confirmation might not trigger exactly where you want it to be, but usually depth of field will be large enough to allow acceptable focus on the desired subject.
12-08-2020, 01:48 PM - 1 Like   #4
I guess the camera cannot memorize the AF adjustment to the specific lens since this is a "rogue" lens in the Pentax database, the camera does not recognize it. So this brings the problem that while you fix this lens you put the others out of focus.
12-08-2020, 03:00 PM   #5
35mmfilmfan's Avatar
QuoteOriginally posted by shyrsio Quote
Surely, as has been said, the Helios is manual focus, so AF adjustment will make no difference.
12-08-2020, 03:43 PM - 3 Likes   #6
clackers's Avatar
QuoteOriginally posted by 35mmfilmfan Quote
Guys, the autofocus system is used in focus confirmation with manual lenses, that's what the beep and the green hexagon is all about.
So microadjustment can of course be done. But without a chip in the lens it'll be universally applied to the camera body.
12-09-2020, 04:13 AM   #7
Thanks for explaining - did not know that ! Live and learn.
12-09-2020, 02:23 PM   #8
clackers's Avatar
Never too late, mate! Makes things much easier.
12-09-2020, 04:00 PM - 1 Like   #9
Then again, one day I'll die and forget the lot. Thank goodness PF is here to make all the useful info available to others.
12-09-2020, 04:04 PM   #10
I am very interested in this subject. Thank you very much for posting this, I am using many manual focus lenses, some very old. Now the focus issues that I encountered make more sense to me and I can adjust my approach.
12-09-2020, 04:29 PM   #11
clackers's Avatar
QuoteOriginally posted by q_crack Quote
Yep, your magnified Live View is great for this, superior to Focus Peaking IMHO. And when many of us can't justify putting a Hoodman or similar loupe on the rear screen, if you're preferring the slower pace of shooting 'many manual focus lenses, some very old', this may be an entirely sensible thing for you to do.
12-09-2020, 05:09 PM   #12
c.a.m's Avatar
Is it possible that the subject you see in the viewfinder is not focused perfectly? I know with most of my manual focus lenses, I have a difficult time to achieve a spot-on focus using only my eyesight through the viewfinder.
As @clackers says, the camera's focus detection circuit and confirmation indicator are used for autofocus lenses and manual focus lenses. Unfortunately, the Green Hexagon is typically illuminated over a range of focus distances, so it is difficult to decide on the correct, true focus position.
You might be interested in this article that describes the problem with the Green Hex and suggestions to achieving accurate focus: Achieving Better Manual Focus with the Green Hexagon - PentaxForums.com
And some discussion on the topic: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/402088-new-arti...n-hexagon.html
- Craig
12-12-2020, 01:15 PM   #13
QuoteOriginally posted by c.a.m Quote
- Craig
Thank you for posting the links.
With manual focusing it helps a lot to first disable the option for the central focus point to glow red momentarily, it distracts the eye. I spend quite a time focusing manually every shot and when I could see the subject as best focused as possible in the view finder, checking with Live View in magnification I could affirm that focus was near perfect. But the Green Hexagon was not lighted at this point. I used AF Micro Adjustment for all and now the Green Hexagon lights when near perfect focusing. If the K-5 had adjustment range from -20 to+20 I could adjust it perfectly. Now I am at -10 and it probably would need -12 for perfection.
12-12-2020, 01:44 PM   #14
c.a.m's Avatar
Good to hear, thanks. Sounds like you're able to achieve a pretty good focus by eye, which is something I have trouble doing even when wearing my eyeglasses.
- Craig
12-12-2020, 02:03 PM   #15
The camera does not recognize it because it has no way to tell the camera its name (id code and unique identifier). No M42 lens has this capability.
BTW... congratulations on success with the "all" option for AF fine adjust on non-AF lenses. There are a couple of users on this site who do that.
adjustment, af, af micro adjustment, camera, exit, finder, front, helios-44m front, lens, lenses, menu, pentax help, photography, troubleshooting, view, zero
Helios 44-2 versus Helios 44, 44-3, 44M, 44M-4... Which is best? interested_observer Pentax SLR Lens Discussion 1 11-03-2020 06:56 PM
Which Helios-44 produces the best "swirl"... 44-2, 44M & 44M-4 tested BigMackCam Pentax Lens Articles 11 02-05-2017 11:34 AM
Little test: Helios 44-3 vs 44M-7 and ST 55/1.8 vs 44M-7 vs SMC-A 50/1.7 malenisjaj Pentax SLR Lens Discussion 8 05-02-2015 01:01 PM
Sibling Rivalry: Helios 44M vs. Helios 44M-4 stevebrot Pentax SLR Lens Discussion 36 08-03-2013 09:31 AM
Helios 44M-4 vs 44M teartear Pentax SLR Lens Discussion 27 08-24-2011 03:25 AM
All times are GMT -7. The time now is 11:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
