12-08-2020, 01:38 PM   #1
Pentax-K70 Tv / Av selection is not working
Hello All,
Got an issue with My Pentax K-70. It is not allowing me to select Av or Tv Mode. When I select 'Av', the screen shows as 'TAv' and allow to change both Aperture and Shutter Speed. When I select 'Tv' Screen shows as "M" and allows to change both aperture and shutter speed.
Tried cleaning the lens contacts, reset to default etc . But nothing seems working.
Auto and M mods are working well. Firmware is 1.11
Got the lens 55-300 DA and 50 smc 1.4 FA, both shows the same.
Please help.
Thanks in Advance.
12-08-2020, 02:18 PM   #2
Check the iso setting, if it is on auto change it.
12-08-2020, 02:31 PM   #3
Michail_P's Avatar
QuoteOriginally posted by shyrsio Quote
The only thing that comes to mind. I can’t imagine it’s a hardware problem. I had a similar issue but with manual lenses. I figured it out. But with af ... strange.
12-08-2020, 03:15 PM   #4
How long have you had this camera? Did you buy it new or used?
12-08-2020, 04:56 PM   #5
ramseybuckeye's Avatar
The ISO setting will not matter, you can have auto ISO with either. I'm stumped, I think you have a mechanical problem and hope you are still under warranty. But hopefully I'm wrong and someone will come along with an answer.
12-08-2020, 05:20 PM - 1 Like   #6
This sounds like a mechanical problem with the mode selection dial not being in proper alignment.
12-09-2020, 08:28 AM   #7
I bought it as new in 2018, its more than 2 years. Hmm So i guess we dont have to try anything. I checked ISO but it didn't help either.
aperture, av, av selection, camera, change, lens, pentax help, pentax-k70 tv, photography, screen, shutter, speed, troubleshooting, tv / av
used Pentax 645z, no TV or TAV modes, just AV when using FA lens... KathleenF Pentax Medium Format 12 11-29-2020 08:32 AM
K3 exposure not works in "Av, Tv, TAv, P" mode nguyenlong Troubleshooting and Beginner Help 6 07-22-2016 02:54 PM
Could Av, Tv, etc. potentially be enabled with Pentax-M lenses through firmware? maltfalc Pentax DSLR Discussion 33 08-29-2015 03:43 PM
HELP - Pentax FA 100-300 f4.7 Lens not working in Av mode gut1kor Pentax SLR Lens Discussion 11 05-25-2011 07:02 PM
Pentax K200d - AV/TV mode problems yeatzee Pentax DSLR Discussion 17 03-12-2010 08:37 PM
All times are GMT -7. The time now is 12:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
