Originally posted by GR Jim Yeah, that's the point. I've seen far too many photos of sunny places that have a flat, nearly colorless appearance due to the effects of strong sunlight. I need the nuances of shadow and rich colors that are difficult to capture in mid-day.
You should be able to get a good exposure in those conditions using ISO 100 f8 and 1/1000 sec. Bracket your shots and do a HDR merge in Photoshop to obtain a wider dynamic range in the image.
A 10 stop ND will simply mean you will need to use ISO 100 f8 and 1 second to get
the same exposure. You will need a tripod and have the twin drawbacks of not being able to use autofocus or see anything through the viewfinder.
ND filters have their uses, but 10 stops are used to create extreme blur in things like moving water and clouds.
