Originally posted by GUB I am not sure what you mean here - Manual mode is nothing to do with focus. I was suggesting manual mode because you don't want the camera changing its exposure between shots. But you have your own solution to that. I choose to be in manual mode all the time anyway so it is not an issue for me.
On the assumption that other Pentax users might also read these posts, my replies were simply trying to be helpful to anyone who is interested, so I'm sorry if part of my post was misleading.
You referred to using stitching to go wider in APS-C using "an older 28mm" lens, and you stated "of course you need to be in manual mode,* which is indeed the case for the older M Series or K Series lenses, which must be manually controlled.
I think this is a great way of capturing a wide (or tall) field of view, without having to buy (or carry) another lens.
However, I sometimes use my DA 35 Limited lens for taking a set of shots for stitching. DA lenses can be used in the semi-automatic modes (P, Sv, Tv, Av, TAv), so with any DA lens it is not essential to be in M Mode, unless you want to work that way.
So e.g. for someone like me who usually has a DA lens on the camera and uses Av Mode, it is not essential to switch to M Mode to get a set of equally exposed shots for stitching, as the AE-L button can be pressed to lock the exposure settings for the set.
Philip
