Show Printable Version 16 Likes Search this Thread
12-20-2020, 08:55 AM - 1 Like   #16
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by Durf Quote
.. . . (I thought I knew everything! haha)
speaking of myself only:
when asked: what do I know?
if being truthful in my response - not as much as I might claim, but more than some ( my brothers and in laws especially ) think
12-20-2020, 09:17 AM - 1 Like   #17
Durf's Avatar
QuoteOriginally posted by aslyfox Quote
I've had the K1 since it was released 4 years ago or so and this morning is the first day I actually realized what the green buttons purpose is and what it could actually be used for!
Embarrassing to admit but I've never needed to use the green button until I got this SMC Pentax 135mm f/2.5 Lens a week ago!
12-20-2020, 01:02 PM - 1 Like   #18
UncleVanya's Avatar
It actually has multiple uses.
Pentax Green Button Guide - Articles and Tips | PentaxForums.com
12-20-2020, 04:23 PM - 2 Likes   #19
Not a Number's Avatar
If you want see the exposure setting set the DOF preview to optical. Disable display of electronic level. Make use of aperture ring is enabled. In manual mode with your MF lens when you activate the DOF preview the aperture should stop down and the exposure value meter should show in the viewfinder. You can then zero or set over or underexposure by changing the shutter speed with the edial or with the aperture ring.
12-20-2020, 06:16 PM - 1 Like   #20
Otis Memorial Pentaxian
It is probably the most useful feature on your camera in regards to exposure and for enabling or exiting from some features. For example, auto-iso is enabled with the green button, as is metering in M mode (even with non-vintage lenses). I believe there is an article somewhere here on PF that provides a fairly complete listing. The camera manual is also a good resource on a feature by feature basis.
12-20-2020, 06:56 PM - 1 Like   #21
Your not alone. I've had a K50/K70 for 5 years, and just figured out the green button last week.
12-20-2020, 07:22 PM - 1 Like   #22
Once you get used to it, green button mode doesn't slow you down that much.
12-20-2020, 08:04 PM - 1 Like   #23
Ok, when in M Mode, if I set the aperture ring to say, F8, and look down in to the lens when I snap a pic I see the blades stopping down (closing) when pressing the shutter button. I didn't know the lens/camera operated this way with manual lenses with the lever.....Obviously I have to shoot this lens in M mode!
Thanks for your help!
Yes, that is right- shoot in M mode and you can use the green button to meter and set your exposure. Once set, you can adjust both aperture setting and shutter speed to get each as you want. With this lens, you might still be able to also use the camera's AE-L feature to lock exposure, so if you use the finger or thumb dial to choose a different aperture or shutter speed, the other will follow along to preserve the exposure value. With manual lenses, the exposure system is not always perfect, but using each particular lens will teach you how far it is off at various f settings, so you'll know in advance from experience.
12-20-2020, 08:14 PM   #24
UncleVanya's Avatar
Steve, look up two posts from yours...
135mm, aperture, aperture issue, camera, lens, lever, modes, pentax, pentax help, photography, reviews, smc, troubleshooting
Lens compatibility and Aperture on a manual MX with a manual Sicor XL MC jkcerezo Pentax SLR Lens Discussion 7 12-03-2018 07:53 PM
K50 + Auto-aperture manual lens issue StormEngineer Troubleshooting and Beginner Help 11 04-23-2018 05:25 PM
Aperture control problems with variable aperture lenses (with aperture rings) gtxSeries Troubleshooting and Beginner Help 3 09-13-2017 01:11 PM
Pentax k52s and full manual lens working issue OvidiuRoSb Pentax DSLR Discussion 5 09-12-2014 11:21 PM
K100ds and full manual mode w/manual lens dwhopson Pentax DSLR Discussion 10 11-06-2008 10:37 PM
All times are GMT -7. The time now is 03:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
