Originally posted by Duowing Helios 44-2 Mounting off with Spotmatic F?
Is this an M39 (Zenit) Helios 44-2 or M42? If M39, the problem may be with the adapter.
M42 pre-set Biotars have clearance problems on some M42 bodies due to having both an ample rear and a shield around rear element. The Helios 44-2, may share that characteristic. Since the SP F has a more constrained mirror box than earlier Spotmatic models, this may be reason for concern.
I suggest visually checking for clearance with shutter on B and the film door open:
- Adjust focus to closest distance and begin threading the lens into the mount, say two turns.
- Continue threading the lens on while looking through from the back (film door open). This is most easily done with the camera on tripod.
- As it comes to close to seating on the flange note check for points of possible interference.
- Once seated to the mount flange, focus slowly to infinity while monitoring the position of the rear element and any shields.
If there is any interference, it should be evident.
